Forum > Sony Ericsson / Sony > Symbian phones > Messed up incoming SMS time
Author Messed up incoming SMS time
QVGA
Nokia Lumia 1020
Posted: 2008-08-01 20:28
The time as stated by my phone of an SMS received is wrong. Its in accurate by +/- 1 or 2 hours. Sometimes its correct and sometimes it isnt which makes it impossible to know when the SMS was recieved.
crippit
Posted: 2008-08-01 22:20
I have had messages from Canada, and it applies the time of sending in the local time zone, which means that it doesn't show the time it arrives.
Does this make sense? I don't know if your messages are being sent from a different time zone?
QVGA
Nokia Lumia 1020
Posted: 2008-08-01 22:28
they are sent from a place 10 minutes away from my house
Mr Miyagi
K850 Green
Posted: 2008-08-01 22:57
i have seen this problem on some nokia fones, don't know how to fix it though. but it is a common problem. some people say u have to make sure the internal clock is set right, which i am sure it is, but the problem is still der.
borjoyzee
W960
Posted: 2008-08-02 05:31
my w960 does the same thing, but its off about 8hours.. my clock is set properly.. don't know!
QVGA
Nokia Lumia 1020
Posted: 2008-08-02 07:15
Yes but in nokia it was possible to know the correct time through the log
IRFCA_WDG-3A
W960
Posted: 2008-08-02 09:16
Same problem here too...sms msgs are off by 2-3 hrs behind time. Also, emails are showing up the GMT which's a good 5.5hrs behind my current timezone. Don't understand...the time as well as home timezone have been set correctly...
