P1i and w960i Dust problem |
IT2005 Joined: Jan 08, 2005 Posts: 31 From: Earth PM |
I am considering to get w960i or p1i. I got bad experience with k600i(dust problem),w890(3 dead pixel), K660i(dust probelm again. Which one of the 2 is more dust screen proof? I heard that w960 got another layer of screen compare to p1i, does this mean w 960i more prone to dust problem? Thanks before.
[ This Message was edited by: IT2005 on 2008-07-03 17:50 ] |
JiSm Joined: Nov 08, 2007 Posts: 404 From: New Zealand PM, WWW
My W960 has no dust problem at all. Mind you, I do use the case that it comes with but being suede, it tends to stick to dust pretty well, but hasnt made its way behind the screen or into the speaker (Rattles).
"Back in the land of the long white cloud!" |
jakontil Joined: Jun 28, 2004 Posts: > 500 From: Changi, Chatswood, Cikarang PM |
Do u mean dust undr the screen? Well mate, got the same problem wit u wit my nonsmartphone like w800, w910 but p1 has been good, as well as w960 thou i hav the same feelin bout the letter since it has outer layer, hence it may b prone to dust. But i may hav to think otherwise nw. I knw that nokia is more prone to dust under ur screen
I  capturing sexy women on the beach  I  This message was posted from an iphone |
ruhvee Joined: May 01, 2008 Posts: 36 PM, WWW
Ive been using a P1i with a screen guard and a flip top cover and after about 4 months, theres no dust underneath the screen.
The build quality is good enough to not allow dust underneath the screen, however basic precautions like a cover and regular cleaning would help.
If dust protection is a factor in your purchase, try the C702, which is dust, splash and a bit more shock resistant than normal phones.
Its a cool piece
None2One Joined: Jan 11, 2008 Posts: 45 PM |
hi ruhvee,
which is the fliptop cover that you use for the P1i. can you share any pics or provide links to see that?
TIA |
thami Joined: Feb 08, 2005 Posts: 169 From: UK PM |
This is what I use for my p1i its not perfect but dose the job.
jeff89 Joined: May 13, 2008 Posts: 229 PM |
w960 is better than p1i because w960 have a flat screen which is not easy to get dust |
Hi None2One,
the case looks like this
theres also a thread on cases for the p1i in esato, you can search for it.
You can order it online from places like this - http://www.expansys-usa.com/zoompic.aspx?type=item&i=155260
Cheers
Waking up to reality. One realisation at a time. |
Ketchup Joined: Feb 13, 2008 Posts: 6 From: Poland PM |
9 months with my P1i - no dust under screen. I use factory case (black shammy). |
whatsucka Joined: Feb 17, 2007 Posts: > 500 PM, WWW
i have been using my w960 for 2 months n i kept it in my jeans pocket... no dust so far
applep800 Joined: Jun 25, 2008 Posts: 14 PM |
I previously using the P1i when it first launch, there are still no dust on the screen & the camera until I change to G900.
Dust only on the keys, M2 slot & the jod-dial only. |
That is pretty good. Although with keeping it in your jeans pocket I thought the lint would get to it sooner or later.
that's it, but i have both and noone sufferring from the lint or dust
bridgstfer Joined: Feb 04, 2002 Posts: 59 PM |
I use the case mostly for my 3month old w960i and this has dust behind the screen already.
No idea how its getting in tho?!" |
