Forum > Sony Ericsson / Sony > Software, Firmware and Drivers > Unable to upgrade firware on unlocked k850
Author Unable to upgrade firware on unlocked k850
pansy potter
Posted: 2008-06-26 20:42
I recently bought an unlocked sim free K850 from expansys. It shows software R1EA031. I loaded the vodafone ireland MMS, GPS and ISP settings and then tried to get a firmware update through SEUS. It tells me that there are no updates available. I uninstalled and reinstalled SEUS but kept getting the same message. I reluctantly did a master reset on the phone and tried SEUS again but still no update available. Now I have lost some of the themes, pictures and ringtones that came with the phone and still have not upgraded my software. What am I doing wrong?
Posted: 2008-06-26 20:45
maybe your phone is branded, it isnt?
you could try 3rd parties like davinici or wotanserver
pansy potter
Posted: 2008-06-26 20:54
no its not branded i got it unlocked from expansys.
rdnymllnsktr
W760 Black
Posted: 2008-06-27 17:32
If you would take a look at the k850i FirmWare thread, you would see that the FirmWare is coming out in different regions at different times. You didn't need to do a master reset...
MyPhoneExplorer is the new FMA!
http://www.fjsoft.at/en/downloads.php
pansy potter
Posted: 2008-06-28 16:08
If I go to davinciteam to look for newer firmware what do I look for?
blerk
T100
Posted: 2008-06-28 19:48
Why not check in which region the firmware you want is released and then tell SEUS you're form that region when you start it?
totalgsm
W910 Black
Posted: 2008-06-28 20:20
Wotan does not support flashing for DB3150 series.
Visit www.totalgsm.org for Remote and Instant unlocking and Debranding services for all Sony Ericsson Phones. Visit forum www.totalgsm.org/forum
