K800i message alerts |
karembu Joined: Jan 29, 2008 Posts: 7 PM |
Hi all,
I recently upgraded from my K800i to a P1i. However, I would like to keep my message alert tone. I tried to send it via bluetooth to the P1i, but it seems that this is not possible for pre-loaded alerts that come with the K800i. Does anyone know where I can get the "Click" message alert?
I found another post about this, but all the links there appear to be obsolete.
Thanks  |
try this:
menu > tools > control panel > device > sounds & alerts
once in there click on the message option and select either "messageclick" or "find sound" and then look for the desired sound.
hope it works
chadiwrx Joined: Sep 25, 2005 Posts: 336 PM |
I'm pretty sure it's the same as the one in S500i.
Download here S500i system sounds
http://www.mediafire.com/?6iekddordz2 |
Thanks I just hope it can use 3gp files as message tones... |
Hmmm....seems it can't  |
