Forum > Sony Ericsson / Sony > Technical > T300 memory issue!?
Author T300 memory issue!?
Plyon
T300
Posted: 2002-12-29 16:23
Hi all,
Hope you can help me out here...
I seem to have found a problem with the memory calculation of the T300, and i cannot image that i am the only one having (seen) this problem.
I ran out of memory, so i started deleting sounds, and images, but as i went on i noticed that in the memory status list the used memory fields (such as 'My sounds, My pictures, etc.') were indeed dropping, BUT the free memory was hardly getting any KB's.
example:
I uploaded a sound to my phone 47KB, all was fine, 47BK added to 'My sounds' and removed from the free memory, BUT
now I deleted this sound again, and indeed 47KB was removed from 'My sounds' but only a few KB was added to the free memory (6KB or so).
So now i entered a sound, deleted it again, but i am 41KB less on memory. And it's getting worse each upload/delete...
Please help me out here.
Thanks.
Incinerator_bg
T300
Posted: 2002-12-29 18:30
this can be a software bug my hard disk is the same dont believe what is writen
Plyon
T300
Posted: 2002-12-29 19:34
hmmz... only one reply yet.. I figured that this would be a common problem.. i tried deleting everything i didn't use, and guess what.. i still have only 126KB of free memory...
Hope one of you has a answer soon
Thanks anyway!
PoloLP
T300
Posted: 2002-12-29 20:31
what's your firmware version ???
!!! Polo !!!
Plyon
T300
Posted: 2002-12-29 20:46
I believe this is it..
R1B008
prgCXC125424
oskar
Posted: 2002-12-30 00:07
I noticed exactly the same problem with my friends t300. Really strange. Maybe i should tell him to get the latest fw. What's the latest version?
This post was posted from a T68i
mattan
K500
Posted: 2002-12-30 14:18
Try this site for the latest firmware versions of SE phones:
http://w1.854.telia.com/~u85424385/fw.html
The latest version for the T300 is R1D011 (as at 31 December, 2002).
Plyon
T300
Posted: 2002-12-30 15:28
Ok, great, there is indeed a newer version available, but how does one update the phone?? Through IR, if so, where can i download the latest version?
[ This Message was edited by: Plyon on 2002-12-30 14:29 ]
imho
T300
Posted: 2002-12-30 15:50
I've got R1D011 firmware, and the same problem
[ This Message was edited by: imho on 2002-12-30 14:51 ]
mattan
K500
Posted: 2002-12-30 16:05
To update the firmware on the phone, you probably need to take it to an SE Service Point. As far as I know, it can't be updated using IR. It can be updated using a cable, the right software and a firmware dump but I don't have the links.
A search here at Esato will no doubt discover more information on flashing.
Plyon
T300
Posted: 2002-12-31 14:06
Ok... well since there are no clear solutions (yet), i will try a master reset, perhaps that clears it up a bit, so that i can start over again...
Something tells me not to though... anyone have 'bad' experiences with doing a master reset?
jellyellie
Posted: 2002-12-31 14:07
i don't have that problem
www.jellyellie.com
imho
T300
Posted: 2002-12-31 14:23
just do a master reset, and don't go looking to the default images
Plyon
T300
Posted: 2002-12-31 14:24
why is that... they all gone??
imho
T300
Posted: 2002-12-31 14:29
they are in the static memory of the phone, but if you go looking at them they're a copied also in the dynamic memory (loose of space)
-> bug
