how to make your w800/w800i louder without any mod |
amid222 Joined: Mar 27, 2008 Posts: 8 PM, WWW
firstly pick out the song you would like to play and set it as ringtone secondly i suggest you put the ring volume as shortcut to the left button (that what i do you don't need to do it just to access it easily) press the pause play button (play any song through the walkman) and while the song is playing you press it left button to go to ringtone volume and the bring it down and then bring the level back up to highest and them the song should start playing very very loud and then just press the walkman button (so you won't interfere with the volume cause it will restart the song) and you'll have a loud phone please not that i have only got it to work on the w800 and w800i |
Cold Fusion Joined: Nov 21, 2006 Posts: > 500 PM |
U cant make ur fone sound louder with a acoustic mod mate
 I  BEING DIFFERENT Previous Username: Ricky_bad420 |
hgautam Joined: Jan 29, 2006 Posts: > 500 PM |
I have been doing this since more than 2.5yr now with my bro's W800 (and my K750 before that)... I had first discovered this trick with P900 some 5yrs back...
So nothing new dude...
And you don't need to do so much. Just set a song as ringtone. Go to volume and then move it down and then up to max vol.
Another trick, play a song in walkman player and set it as ringtone too. Now without pausing the song in walkman player go to volume and move the bar down and up again. The song will start playing at ringtone. Press the walkman button and go to equiliser and move the middle and second last bar to the max level. You will notice an even higher volume.
Even more by putting ur phone on a table.
[ This Message was edited by: hgautam on 2008-03-27 19:02 ] |
By the way is there a sound acoustic driver for W800 that can make it's walkman player volume louder??? |
Yes there is , i use BLACK ICE wowII and its loud enough mate. Give it a try
Please, a link to it's download???  |
Sure here u go : http://rapidshare.com/files/103322047/Black_Ice_WOW_II.zip
Sayers 2k7 Joined: Apr 02, 2008 Posts: 1 From: United Kingdon PM |
[quote]
[/quote]
Then What Do you Do? |
Ranjith Joined: Dec 07, 2004 Posts: > 500 From: Saudi Arabia/India,Cochin PM |
search for a guide on how to use FAR manger to mod W800.
I  ESATO I  W1i  T20,T65,  P800(2x),K800,Z300,  800,  850 (2x),P1i(with WALKMAN) |
@Cold Fusion
Thanks a lot... It's much much louder now... |
Senchiiro Joined: Aug 04, 2008 Posts: 5 PM |
i had download it,but idk wht to do next.
can tell me? |
AHRum Joined: Aug 01, 2008 Posts: 7 From: Bangladesh PM |
U can use XS++ to upload it easily..i think u shud take a luk 2 d tutorial..u may find it in our forum... |
U have have to replace with ur other acoustics in ifs/settings/acoustic. Search this forum how to do it.
sunils120 Joined: Nov 08, 2006 Posts: 480 From: India PM |
Rakista monster bass is also a good substitute for your default acoustics!
i  my k700i and  810i |
strizlow800 Joined: Aug 23, 2006 Posts: > 500 From: Macedonia, Skopje PM |
Check se-nse.com for toshara's acoustics... They are also pretty loud...
