Forum > General discussions > Other manufacturers > help with n958gb as mass storage
Author help with n958gb as mass storage
frank2345babies
W900 white
Posted: 2008-02-14 21:26
hi there i was just wondering if anyone could offer some words of advice. basically when i try and connect the n95 8gb to a computer as mass storage an error message keeps appearing on the screen(phone) saying mass memory in use by another application but i have no applications running and cant think of any applications that may be using it. any help is appreciated
shanespencer
Posted: 2008-02-14 22:34
I get that sometimes, too. Try turning your phone off, then switching it back on. Reconnect it to the PC as soon as the phone reaches the desktop. That seems to work for me.
drgopoos
Posted: 2008-02-14 23:05
check if you are using the mass memory as the place were you store the messages.
if yes then change that option back to phone memory and then connect to pc
frank2345babies
W900 white
Posted: 2008-02-15 09:52
will change texts back so they save on the phone and if that dont work will try turning the phone off etc thanks for the help will let you know how i get on.
