K850I - Memory card not detecting properly in xp |
freestyle Joined: Jan 27, 2004 Posts: 172 PM |
Have a problem with a pc running windows xp professional in that it only provides the phones internal memory as a selectable drive.
The pc knows the memory card is also there as it lists two generic volumes in the hardware list but isn't giving the memory card a drive letter.
Anybody else have a similar problem? |
robmac Joined: May 17, 2006 Posts: 33 PM |
connect up your data cable and select mass storage on the phone menu, and have the setup disc in the cd drive just in case it dosent work it will find the drivers from it and then it should work.
My operating system is xp professional and it works on that ok |
mrjlaunch Joined: Oct 16, 2007 Posts: 3 From: Australia PM |
Yes, I just got my K850i today and I have the exact same problem! Windows XP can see it but "Sony Ericsson Media Manager" can't. |
