K810i Gmail-problems |
Flame2k Joined: Dec 10, 2005 Posts: 7 PM |
I have a Sony Ericsson K810i and I can't get Gmail to work properly with the inbuilt e-mail client. I can read and get new mail but not send any mails. I tried to install the three certificates via FileManager, and I put all the three certificates right on the K810i icon (to the roote i hope) but it didn't work. I just woundering where did all the three certificates go? My earlier phone V800 asked if i wanted to install the certificate when I placed it as i described earlier in the message. |
glorfingal Joined: Jun 10, 2006 Posts: > 500 From: Bristol,UK PM |
my k810i (O2 UK) didn't require any certificates to get G-Mail
working. I can send and receive e-mails using the in built client.
What settings have you got ??
I reject your reality and substitute my own. |
aatuif Joined: Sep 04, 2006 Posts: > 500 From: KASHMIR PM, WWW
use the gmail app, that's also good...
else you can go thru the gmail config. threads in this forum...
This is my settings:
E-mail: myadress@gmail.com
Mailtype: POP3
Incomming server: pop.gmail.com (TLS/SSL)
Username: myadress@gmail.com
Password: mypassword
Outgoing server: smtp.gmail.com (TLS/SSL)
Incomming port: 995
Outgoing port: 465 |
please go thru the gmail config thread once, you'll def get it to work... lots of stuff there...
hhmmm .... my setup has pop.googlemail.com Not pop.gmail.com and
likewise for the outgoing (smtp) server address even though the
e-mail address is blah@gmail.com.
Also - definately set to SSL for both in and out ?
Nothing works and now the demo tour video dissapeard and some menu in the Memomry Stick like certificates or something, I'm getting crazy of this Sony Ericsson K810i shit!!! |
jemuel Joined: Sep 21, 2006 Posts: 124 From: PH PM, WWW
where can i get certificates? please help!!!
I  my k608i I  Esato |
U-D13 Joined: Jul 03, 2007 Posts: 7 From: Riga, Latvia PM, WWW
@jemuel and others
There's kinda guide on Gmail here (tho it didn't help me a lot - I still can't send mails):
http://www.diezilextra.wen.ru/Gmail/
- RTFM!
- What manual?!
[ This Message was edited by: U-D13 on 2008-10-24 02:14 ] |
the guide is presently in a good way, but didn't help me technically...
But it DID help me... i've just installed the certificates from the site just like what flame2k did; i dragged it to the root using file manager and the phone asked me if i'd like to install it. Just tried Gmail and receiving email works perfectly. but sending email is kinda slow (I'm within 3G network).
I my k608i
I Esato
[ This Message was edited by: jemuel on 2007-07-19 10:41 ] |
altemyr Joined: Jan 21, 2002 Posts: > 500 From: Stockholm, Sweden PM |
I had a similar problem with gmail on my k800 before I installed the certificates. Now it works perfectly.
It should work to drop the certificate files directly on the phone icon, or, by using bluetooth, send them to the phone using the proper option in the file context menu. An alternative (haven't tested that) might be to put the cert files in the 'other' folder, and in the phone 'open' them. |
Delta 9 Joined: Mar 26, 2003 Posts: 193 From: The Netherlands PM |
I also have a problem getting Gmail working with the inbuilt client, I'm on T-Mobile (NL). I have installed the certificates and followed all the instructions (read the tread from front to back). What am I doing wrong?
4000 Miles an hour in a jet-airplane...... GO OUT OF YOUR MIND GO INSANE!!!! |
naji123 Joined: Nov 21, 2006 Posts: 20 PM |
try to download the gmail application into your mobile its better i have k810
visit this site from your mobile http://gmail.com/app |
Thanks for the suggestion naji123, I'm currently using this application only I find the fact I cant send mail with attachments annoying. That's why I'm trying to get the build in client to work. Unfortunately nobody from the Netherlands seems to have any expertise on the matter (judging from the lack of response). |
