P990i Radio don't work |
digitalriver Joined: May 10, 2007 Posts: 4 PM |
Having trouble: attaching handsfree, all OK.
Trying to turn on radio, media player freezes until I remove and turn back handsfree. Then the radio interface appears.
But... no sounds in headphones at all. At the left side of the screen the mute indicator lit. When turning off - nothing changes.
Trying to set frequency manually - no result, still 87.5.
No zone, no RDS, no sound.
Firmware: last (before flashing problem already was).
Handsfree: 100% workable (at another P990i radio plays, at my P990i I can speak by phone, so, wires not affected).
Has anyone something looks like this?
[ This Message was edited by: digitalriver on 2007-05-10 21:19 ] |
amanno1 Joined: Sep 05, 2006 Posts: > 500 From: HELL ON EARTH PM |
As far as im aware,and mine is in front of me,there's no radio on the p900i!! |
Ekhm... sorry, P990i |
antichrist Joined: Sep 26, 2006 Posts: > 500 PM |
you said "before flashing problem already was" so this means it's a hardware problem. since when your radio stopped working?
Radio don't work since I got the phone in april 20.
You're right - sure that's hardware problem also.
May be You have any solutions or service manuals? |
cauer Joined: May 15, 2007 Posts: 1 PM |
Hi,
I have exactly the same problem than you after a software upgrade i.e.: The radio does not work, when starts is muted and hungs up until I remove the headphones.
Did yiu find a solution?
/Manuel |
log Joined: Nov 15, 2004 Posts: 64 From: Boring London UK PM |
I too have just updated and now have a corrupt radio, when i try to start it it says corrupt, thats it!
It was working perfectly before the firmware change.. I did a restore before i tried it so it could be the restore .
I guess i could of tried it before restoring but you dont expect the update to break things. It also corrupted my Opera so i had to install again, there a new version now anyway.
I like the new loading bar and the volume is definately louder through speaker and bluetooth! |
Sorry for the long time without answer.
Cauer: sadly no. And noone has heared about such problems.
Probably it's really hardware problem: breaked circuit, burned part...
Log: Is this thing really appeared after the software update?
A new loading bar is really what I was waited for  |
Yes my radio stopped working after latest update, the one with the progress bar on startup. It worked fine before, but i only tested it after restoring a backup. |
hgautam Joined: Jan 29, 2006 Posts: > 500 PM |
I encountered the same radio problem 7 months back and i was never able to find a way out... Finally, I went to SE Service station and they replaced the whole handset for me... |
Mm Joined: May 28, 2007 Posts: 8 PM |
Mine radio also stoped working after SW update. When I try to start it, it just says CORRUPT. Nothing else and it fckn pisses me off! Any news about it? |
ares Joined: Dec 11, 2003 Posts: > 500 From: Coimbra, Portugal PM |
its simple...master reset or format internal drive and do not restore old backups...if the problem is not hardware related, this will fix it
SE w880 + Iphone 4 16gb |
How can I get thing back on as they were (settings and data) if not restoring? |
Cycovision Joined: Nov 30, 2003 Posts: > 500 From: England PM, WWW
You can't revert the firmware (software) by restoring so I guess the only way would be to flash the phone again with an earlier version of the software.
SEUS can't (or won't!) do this, not sure if one of the online services like wotan or davinci can? Maybe somebody can shed some light on this?
Most of us with R5A17 have the radio working, people that donīt have it working suffered from a bad flash process, so to correct it they need a master reset/internal drive format, with or without a reflash (makbil reported he just had to make a master reset and the radio started working again)
About restoring old settings and data, for people with severe problems like these should make it all manualy...but hey, it might work just doing a master reset and restoring the settings normally...
P990i + hbh ds970
http://pbase.com/ares - photography by ares aka antonioj
[ This Message was edited by: ares on 2007-05-28 16:48 ] |
