K800i Camera Problem |
stacey10 Joined: Mar 16, 2007 Posts: 4 PM |
For A Long Time My K800i Had Been Fine Up Until Now. I Contacted Sony They Told ME To Update The Phone Which I Did All My Settign On The Camera Are Set To Defalt And This only Happenss To certain Images I Have Taken. Any Body Any Ideas?
I Will Upload An Example To See If any Body Else Has Had The Same Problem Thanks.
[ This Message was edited by: stacey10 on 2007-03-16 10:31 ] |
Very strange! The only thing I can think is that there is a problem with the ribbon cable that connects the camera to the phone's mainboard, that there could be some damage to that.
When you say certain images, what do you mean? Is it only those taken in dark conditions, or when the flash fires, or in certain modes?
By Certain I Mean Every Picture I Take Does not Turn Out like This Its Just A Few It Varies.. It Can Be Daytime Or Night Time.
Quite Annoying Really Because It Can Just Happen Randomly And A Great Picture Is Then A Rainbow. It Has Been Sent Away According To Argos And If It Can Be Repaired It will Be. If Not It will Be A Replacement
What Do You Think The Chances Are Of Getting a New K800i??
Heres Another Example.
Hmmm, so it's totally random then? My instincts still think it's a problem with the ribbon cable, which is repairable.
The phone though is obviously not working as it should, so get it sent back. I can't say whether you'd get a new one or the other one back, but at least you should get a fully working phone at the end of it hopefully!
Mostly During The Day When The Sun Is Out. Yep Hopfully They Will Be able To Sort It Well Im Due To Get It Back A Week On Monday so I shall Let You Know What They Say! Strange Though How Nobody Else Seems to Have This Problem. |
Lo-couk Joined: Dec 14, 2006 Posts: 270 From: West Yorkshire England. PM, WWW
It looks to me as if you have the camera set to Solarize in the effects menu...
iphone 4 16Gb |
rockafeller Joined: Nov 24, 2005 Posts: 29 From: Caloocan City (Philippines) PM |
yep.. it seems that ur camera is stock on polarize effect.. hope you got it repaired soon..
Phone Model: K850i | N95-1 (Hacked) Last Phone Used: Nokia N73 |
Mazatan Joined: Feb 05, 2007 Posts: 13 PM |
Make a master reset or try to switch the preset to other than solarize |
Thanks for all the info guys!
Well for my good Argos gave me a replacement
because i had proved to them there was a fault with the phone although their repair people said there wasnt. I have noticed a few changes with the new one the camera cover is slimer and the sound seem a tiny bit better. |
The camera cover's slimmer? I don't think they've changed - unless you've been very lucky and they've given you the new K810i!
talktoanil Joined: Mar 11, 2007 Posts: 4 PM |
ya very tue.......... |
murali047 Joined: Aug 20, 2010 Posts: 1 PM |
hi sammy i am also now facing the same prob for my k800 whats solution can i get pls help does software reset help to come out of this problm.. pls reply |
