Do you have same problem?? |
katesaia528 Joined: Oct 28, 2002 Posts: 39 From: Macau PM |
Sometimes, when the phone already connect with someone, but I can't hear anything, i only can say "hello...hello....hello", after then "someone" will call u back and said why u just say "hello...hello....hello", who can tell me is it error on my moblie or someone's mobile....? f**k it dam.....waste mins. |
Dj Boyi Joined: Oct 05, 2002 Posts: > 500 From: Liberty City PM |
U need to press >*<<*<* then service tests then microphone to test it,if it dont work u need to take ur phone back to the shop u got it from,i had the same problem and had it replaced:-)
This post was posted from a T68i |
Mitz501 Joined: Sep 22, 2002 Posts: 39 PM |
That also happens to me! I have to adjust the listening volume everytime i pick up a call!
i think is not the volume problem, cos sometimes I redial to someone, the tone is normal, it's work. This status i try so many times....dam it. |
>Ukalo Joined: Oct 09, 2002 Posts: 3 PM |
This can be also network problem, and i think it's most probably reason... Sometimes happens :-(
This post was posted from a T65 |
@kate did u do the service test?
[MDS] Joined: Oct 09, 2002 Posts: > 500 From: U.S.A. PM, WWW
i don't have any problems like that, unless the network signal is weak and i am breaking up, but in this case it is clear that this is the issue...
www.mythstudios.com |
@katesaia TAKE THE PHONE BACK,GET IT REPLACED,I HAD THIS PROBLEM SO I HAD IT REPLACED,NO PROBLEMS SINCE:-)
Boyi..........yes, i tested."THANKS".......! It's normal, and the sound so loud. I really don't know what happens....! Network problem ? Mobile problem?? Replace a new one, you're joking. Do you know where i am living?? In the Chinese place these are rare services, but I'll try.
**My English is poor, hope u can understand what i am saying! |
f**k |
Hahahaha.....I just test this forum, slang is not allow, this is a polite forum, right?!! |
hope so,and yes,i understand every word,and enjoy ur t68i:D |
