Nokia 7210 can't send or recieve audio?!?! |
risk Joined: Apr 05, 2002 Posts: 16 PM |
Hi
Playing around with my Nokia 7210 I have found no way to add a voice-message to a MMS.
If I try to send a MMS containing a audio-clip (amr) from my t68 to my 7210 the amr-file cannot be played..
am I doing something wrong or has Nokia actually made a MMS-capable phone without audio-support?!?!
Maybe they should call it SMS again - Singlemedia Messaging Service  |
gadgetboytom Joined: Feb 12, 2002 Posts: > 500 From: London PM, WWW
oh dear i thought this may happen seems that and nokia have diffrent ideas about what mms is
t68i's dont support midi over mms
7210's dont support amr over mms
whats your software version maybe it needs sorting out
P1i and E51 |
My firmware-version is:
v. 3.09
02-10-02
so I would guess it's only 23 days old...
I think SE has got the better idea when it comes to which audio to support though... if you consider MMS meaning Multimedia Messaging Service, .midi isn't really very good for Messaging between people in an effective way
Although I'm pretty confident that my 7210 will be able to recieve polyphonic ringtones (.midi) through MMS (haven't tried yet though) I have found no way to add a polyphonic ringtone to an MMS either....
Den Joined: Mar 18, 2002 Posts: 99 From: Finland PM, WWW
This one is from NOKIA 7210 instructions:
" MMS supports the next file formats:
- Pictures: JPEG, GIF, PNG and BMP.
- Sounds: Scalable Polyphonic MIDI (SP-MIDI) and monotones (RGN).
If received message have parts that phone doesn't support, at their place will be the name of received file and message: "Phone doesn't support this object" " (this is translated from finnish!) |
Lucke Joined: Jan 03, 2002 Posts: 52 From: Sweden PM |
As far as I saw, it was not possible to add ringtones to an MMS in the 7210...tried with the ones delivered with the phone and no go....
Also, they are only 2 pages?
Good display, but the implementation of the rest of the stuff? Time to tie the knot if you ask me... |
