Forum > Sony Ericsson / Sony > General > Scratches on my K800i?Need a solution.
Author Scratches on my K800i?Need a solution.
Dan_89
Posted: 2006-07-23 14:30
Hi i bougth my K800i about a week ago and now i've got two ugly scratches on the rigth side of the display.On the black list(dont remember the rigth word).Damn ugly scrathes,not so big seems to be dirt at the first glance.The color is silver and yes ugly.I have used the phone very carefully and caring about it.it has been lying in my pocket.and it scrathes.!?
Someone know how to remove och some way to style theese scrathes away?It is very disturbing and ugly.
"I apoligize for my bad english its been a while since i was in school,springbreak and all".
shaliron
K610 red
Posted: 2006-07-23 14:33
Well you can either use Displex or you could read this thead as an alternative.
A wooden spoon is a spoon made from wood.
Source: Wikipedia
[ This Message was edited by: shaliron on 2006-07-23 13:41 ]
Dan_89
Posted: 2006-07-23 14:40
but the scratches is on the black painted plastic and not on the display.But it maybe working on that too.?
Tnx for the fast answer
shaliron
K610 red
Posted: 2006-07-23 14:45
I've ever repaired scratched plastic before, but I think that it can be solved by a nice paint job. The other alternative is to buy a new outer case for the K800, but I don't think that one for the K800 is availible yet. Otherwise could someone else give another suggestion?
By the way. Welcome to Esato
Lleoman
Posted: 2006-07-23 19:57
Suddenly I've got lots of small scratches on my K800i screen. It's been in my pocket most of the time so it's kinda strange. The scratches disort the backlight and are really irritating Is there a way to remove or reduce them? Something cheap (like toothpaste) would be good, has anyone tried it? I know there are lots of polishers like Brasso, Displex and iCleaner but if toothpaste works well I would be really happy.
I've ordered a Martin Fields screen protector so I hope I can get the screen a little less scratched before applying the protector.
Please help!
The pessimist complains about his over-boiled potatoes. The optimist makes mashed potatoes.
Varty
Posted: 2006-07-23 21:05
Displex did't work well on new models i used it on my k750 the displey of k750 and k800 is cover with mirror like glass not like the older models . I read threads abaout wonderful DISPLEX and i only got more scratches. DISPLEX is some kind of acid and burn my keypad . Try to buy new cover! This is the only solution don't waste your money with paste.
masterp
W200 Black
Posted: 2006-07-23 21:16
i was the one that posted the reply with toothpaste , a guy on a market told me that to remove scratches from cds , dvds and displays .
i never used it on displays but on cds and ps2 dvds it works like a charm ( you have to use a regular toothpaste (plain white stuff) )
another option was the use silver or copperpaste , again worked good with cds and dvds , but never tried it on a display
proud owner of a 800i , 200i , p910i + route 66 mobile 2006 and a hbh-600 , gave my k800i to my girl ( enjoying my new WII and DS lite )
Lleoman
Posted: 2006-07-23 21:20
Might as well try some toothpaste... what kind of cloth do I need?
ghostfreak
Samsung Galaxy S II
Posted: 2006-07-23 21:22
Could you post some pics of what the scratches look like?
http://www.ghostrx.net
T300 > T610 > K700i > K750i > K800i > K850i > W910i > K850i (after flash with R1FA035) > C905 (broken earpiece as of 23/01/09) > BB 9000 > BB Bold 9700 > SE Experia X10 Mini Pro
Lleoman
Posted: 2006-07-23 21:32
If it was my scratches you meant, here you go:
http://img45.imageshack.us/img45/2559/dscn8939zo0.jpg
Most in upper right corner.
Dan_89
Posted: 2006-07-23 23:38
here is some pictures on my scratches.The photos is taken with an Samsung X640 not so good quality but you will se the ugly scratches.
[ This Message was edited by: Dan_89 on 2006-07-23 22:42 ]
michka
Sony Xperia E1
Posted: 2006-07-24 00:22
Using tooth-, silver- or copperpaste is good for "removing" scratches from plastic. But it won't do much good with paint.
Simply because the so-called scratch removers work by gently removing material around the scratch, not the scratch itself. It works by removing, around the scratch, a thin layer of material the depth of the scratch.
Now, do that with paint... and you most probably remove it all around the scratch. And you end up with a big spot without paint.
Pedestrian: don't run, my car is faster anyway.
SonySandy
Posted: 2006-07-24 12:19
I've got a small chip in this alloy type panel on my K800 too, after i dropped it in the car. Its definately not plastic... touch it to your lips, see how cold it is! Its not plastic.
Best bet would be a black touch up paint stick, but it will never be seemless.
>500
Vivaz Black
Posted: 2006-07-24 12:24
what material is the k800i made from?
SonySandy
Posted: 2006-07-24 12:32
Mainly plastic and that ally panel on the front in shiny textured black, same material as used on the area surrounding the keypad on the K750.
