K750i star key does not work? |
Gazza_1989 Joined: Jun 15, 2006 Posts: 154 From: UK - Northamptonshire PM |
I have recently bought a K750i and have found that the Star key (*) does not work. I have change the keypad and still the same result.
I am not sure whether it is a connection that has broken or maybe a software problem?
Please help!! |
k4m!k4ze Joined: Oct 02, 2004 Posts: > 500 From: CBE PM |
I doubt that this could be a software problem. Only solution would be to take it to the authorised SE service center and get it repaired by them.
If at first you don't succeed, destroy all evidence of your attempt !! |
ok thanks
any more ideas anybody? |
hairytea Joined: May 10, 2006 Posts: 164 PM |
On 2006-07-04 14:40:50, Gazza_1989 wrote:
ok thanks
No because k4m!k4ze is right.....
[ This Message was edited by: hairytea on 2006-07-04 14:19 ] |
ok thanks alot!!
will send it off soon thanks for the help guys!!  |
