Unlocked SE Q's |
Jowi Joined: Feb 21, 2002 Posts: > 500 From: Pilipinas PM, WWW
When you go to the service menu, service info, & to the SIMLOCK menu...the data that are in displays are:
Network - icon (lock/unlock) - number
Network subset - icon (lock/unlock) - number
Service Provider - icon (lock/unlock) - number
Corporate - icon (lock/unlock) - number
ESL - icon (lock/unlock) - number
If an SE phone is originally openline or simlocked, the number that is in display is 5.
If an SE phone that is previously simlocked & unlocked, what number is in your phone? When i had my phone unlocked, the numbers changed from 5 to 9. Is this normal?
SilentSniper Joined: May 27, 2006 Posts: 1 From: Denmark PM |
Your phone is properly "BROWN" insted of "RED"
Brown developer firmware
Red retail firmware
You can check your phone for free using the http://www.davinciteam.com client
And you dont need a account to do this, just run the "Read CID/Test cable"
My own K750i is sim unlocked with USB-Smart, and my phone is red.
And the number is 5 insted of 9 that you have, is it normally i dont know.
When you run the client program, you will se something like this:
Client Version 15.95 ****
READING CID STARTED ****
Turn off the phone. Hold "C" button and plug USB cable. Phone attached! Detected SonyEricsson: K750/D750/W800/W550/Z520/Z530. Status Ok, OTP Close, CID49, PAF1 IMEI: xxxxxxxxxxxx
Phone CID 49, Color RED
You must use CID49 Flash Files For this phone!
Press button - "Get Files From Web" and download free firmware Execution
[ This Message was edited by: SilentSniper on 2006-05-27 22:50 ] | |
