K750i 'Screen Flashing' problem. |
snowdevl Joined: Feb 11, 2006 Posts: 172 From: Auckland, New Zealand PM, WWW
Hey guys.
My K750i has developed a problem where the whole screen will flash white, then go blank over and over.
This happens whenever I connect the phone to something. It will happen when I connect it to the charger, or the USB data cable.
It also happens when turning the phone on. E.g. ...the phone is off, I press the power button, screen starts flashing for around 5min, and then either the phone will turn on, or it will stop flashing and not do anything at all.
I searched, and another member has also had this problem, but nobody gave him a very helpful answer. The link to his thread is here.
Cheers for any help at all
I'd run a mile for a snowdevl!
[ This Message was edited by: snowdevl on 2006-02-17 09:49 ] |
The only thing I can think of it that it's a firmware issue. Try updating the firmware on the phone (via SE's website) and see if that makes any difference. If not, it may have to go back to SE to be looked at, it should still be under warranty
Thanks for the response.
Have tried updating the firmware, but it does the same thing i.e. when I plug the cable into the phone the screen starts flashing...
The phone is not under warranty as it is imported. There are no Sony Ercisson stores in NZ so the only place to get them from is Vodafone, but I didnt want their ugly branding and menus etc.
I'd run a mile for a snowdevl! |
The other option, though it will cost you a bit of money, is to take it to a local phone repair shop and see if they can do anything with it, or see if someone from here on Esato might do it for you!
Hehehe yeah I was hoping someone here would be able to come to the rescue.
Im a student earning a very small amount of money and would prefer not to have to pay for a cellphone repairer to fix it, also they seem to take forever, I know someone who took a phone to get fixed and they had it in their shop for about 3 weeks before they decided to do anything with it.
Also, my firmware version is R1AA008. That doesnt mean much to me, but yeah...lol
KNIGHT51NZ Joined: Feb 16, 2006 Posts: 88 From: Brooklyn, Wellington, NZ PM |
I'm in NZ and I've got the cable and software, so ya can send it to me to have a play with if you want, but if it needs to be updated with DaVinci or somesuch (if the firmware is damaged or the phone has been incorrectly unlocked) then you'll have to cover the cost of the credits from them (works out about NZ$25ish to do a full unlock & upgrade).
PM me if ya want. The mobile phone repair shop is also able to do this but it'll cost you plenty.
Where abouts in NZ are ya.
No offence or anything, but I dont really want to send the phone off to a complete stranger. If you are in Auckland though, maybe we could work something out?
How much do you think i'd be looking at to get this fixed from a mobile phone repair shop?
[ This Message was edited by: snowdevl on 2006-02-17 10:32 ] |
Mobile phone shop repair HQ is in Auckland somewhere, around $100 wouldn't surprise me, give them a call and ask.
The official people are: www.mobilefonerepair.com
They're in Mt. Wellington.
Ah, thanks alot for that mate!
I actually bought the phone off Trademe, and have just emailed the seller asking him to pay for the repairs, as in the auction he stated the working condition as 10/10, when it obviously is not (i've had the phone for only 3 days)
Actually I just remembered a mate of mine's girlfriend works at 'Digital Mobile' (not sure if they have stores in Wellington??). Might find out if they do repairs too, might even get a discount since I know the person... cant hurt to find out... lol
Digital mobile is listed as a service centre, so they can probably sort it out for you. Presumably they just send it to the other repair people, but they might be able to do you a deal. The Vodafone repair guys (mobilefonerepairs) tend to be a bit quicker than Telecoms repair agents (I'm assuming they use different people due to the fact Telecom tends to take about a week and a half whereas Vodafone usually is 4 or 5 days.)
Glad some white 'Knight' has ridden to your rescue!
That's the latest firmware version you have on that phone, so it could well be a firmware issue or a botched unlocking as Knight has said.
Best thing I could suggest is to send the phone off to one of these mobile repair places, or to Knight if you feel you can trust him (mean no offence there Knighty!), and in the meantime get yourself a cheap phone like a 3310 or something just to tide you over whilst your phone's away being repaired. Some repair places may give you a 'courtesy' phone, but check this out as some don't.
Cheers guys!
Knight, Digital Mobile is a Vodafone repair agent isnt it?
They wouldnt surprise me by uploading the Voda Firmware on the phone, to my disgust, would they? Lol.
Sammy_Boy, yeah already got a cheapo phone, which I was using temporarily because my old t630 suddenly stopped working (buttons dont work), so I could use that.
Thanks for the help people
The buttons on your T630 could be fixed by taking the phone apart, and ensuring the keypad PCB is plugged properly into the motherboard. Try taking it out (by lifting the metal bar, pulling the connector out, reinserting it then pushing that metal bar back down securely) and re-inesrting it, buttons may then work.
I've never looked at the insides of a phone before so I wouldnt really know what i'm doing.
Never pulled a phone apart either, a T630 cant be too complicated can it? Worth a go?
I had a topic up about the t630 earlier, go here if ya wanna have a read -
http://www.esato.com/board/viewtopic.php?topic=115400
