Refurbished MS pro duos? |
ade_waqar Joined: Feb 09, 2006 Posts: 54 PM |
Can anyone tell me of a site which sells refurbished MS pro duos which are cheaper than the newer ones...act i know about EBay n all...but the prob is tht they dun ship to my country....i.e. Pakistan...so can anyone help me here? |
KNIGHT51NZ Joined: Feb 16, 2006 Posts: 88 From: Brooklyn, Wellington, NZ PM |
How on earth do you refurbish a memory stick? Why not just buy a second hand one? |
ya probably thts wat i shud hv said...sorry wrong choice of words...ya i need a 2nd hand one... |
rhythmeister Joined: Jan 02, 2005 Posts: 24 PM |
2Gb ones are now under £40 on fleabay, same as what I paid for my 1Gb 2 months ago
tHatDudeUK Joined: Sep 23, 2002 Posts: 50 PM, WWW
Warning most 2gb sticks on Ebay are fake! |
$hé®îNghÀm3:16 Joined: Jul 09, 2004 Posts: 379 PM |
I suggest Sandisk's 2gb, if you consider buying from ebay.
So far there are no fake sandisk pro duos. |
H m m m m m . . . this is alarming, if TRUE !
leeboy13 Joined: Sep 28, 2005 Posts: > 500 From: Brissle - dodgy accients PM |
depends really if bought in the UK,,, if bought from China then sure its a fake most likely... generally if bought within the Uk off ebay, theres a good chance its real
Check teh forsale accessories here mate, people are always selling secondhand ones  |
