w810 q's |
Ranjith Joined: Dec 07, 2004 Posts: > 500 From: Saudi Arabia/India,Cochin PM |
well...........i read the review on w810 frm mobile-review.....n i have few q's.....
"Package:
* Handset
* Battery BST-37 Li-Pol 900 mAh
* Manual
* Disk with software PC Suite, includes Disk2Phone
* MS Duo Pro 512 MB memory card, PC adapter
* Charger
* USB-cable for synchronization"
acc.to the abv info on mobile-review,there isnt a headset included!!....is it true or a mistake????
"Radio. You can keep up to 20 stations in memory, automatic tuning and RDS are at your
disposal. The phone has the same radio quality as the K750i, which is rather high.
HPM-70 stereo headset is included into the kit, but in contrast to previous versions
the earphones imply no rubber insertion for wearing on the neck. They are simpler and
feature only thin wires. They both look plainer and transmit sound worse (subjectively
the quality is lower)."
acc to this there is a headset........luks like its no the same 1 included in the other w phones...
coz it says "transmit sound worse (subjectively the quality is lower)"
......is tht too true???....
tq
I  ESATO I  W1i  T20,T65,  P800(2x),K800,Z300,  800,  850 (2x),P1i(with WALKMAN) |
Well, the phone isnt even out yet and AFAIK nobody on Esato has one.
We wont know how good the sound quality is until the phone is released or some lucky punter manages to bag one early.
I doubt the sound quality will be much poorer, otherwise it wouldnt do SE's Walkman product line reputation much good.
captainsms has them for sale!
mebbe he can answer?
fatreg
captainsm Joined: Jun 25, 2002 Posts: > 500 PM |
The ones i have for sale has got the same headset as the regular W800's. |
