Forum > Sony Ericsson / Sony > General > debranding and SEUS for o2 branded k750i on t-mobile USA
Author debranding and SEUS for o2 branded k750i on t-mobile USA
shimmer220
Z800
Posted: 2005-12-19 19:16
[ This Message was edited by: shimmer220 on 2006-07-25 00:58 ]
Beep
Posted: 2005-12-19 19:42
As long as you can get WAP/MMS and your Voice Mail to work with the T-Mobile SIM and the icons don't bother you then no point in the update / debranding.
SEUS won't update or debrand the O2 phone you have so the only option is a pay-for-it or be a DareDevil.
Your phone's unlocked though ~ have you ever done a Master Reset?
shimmer220
Z800
Posted: 2005-12-20 01:17
I changed the WAP and messaging profiles so everything works. Oh I didn't know SEUS didn't work for O2 phones so thanks for that tidbit.
I haven't done a master reset but I'd deleted the extra icons/profiles that weren't protected. What else would master reset do?
Thanks for the help man!
Beep
Posted: 2005-12-20 10:43
It'll delete everything that wasn't part of the Firmware.
So everything you store on the phone's memory will be lost.
Call Contacts (so put on SIM or backup (backup anyway))
Pictures
Games
Applications
Music etc...
What's left may be less than what was on your phone at purchace.
But most (if not all) can be got either from SE Support or Download area.
If you have bookmarks, move to ExtMemory.
~ I think
