Forum > Sony Ericsson / Sony > General > Cant change FM channels while in minimized mode
Author Cant change FM channels while in minimized mode
funtoosh
Posted: 2005-10-18 15:24
hi,
in w800i i'm having R1L firmware. i'm not able to change the channels of my FM Radio while its in minimized mode. in my old Nokia phone i used to change the channel by pressing the accept button of my headphone.. is there any such setting in W800?
Funtoosh
turt
Posted: 2005-10-18 18:12
Just hold the volume button up or down and your phone will check for upper or lower frequency channels
iambasil
Posted: 2005-10-18 22:06
Shame it won't go through the presets though. Same with K750
max_wedge
Xperia Neo Black
Posted: 2005-10-19 09:47
agree. I would have thought it'd make more sense to make it scroll through presets rather than all available stations?
judge
Posted: 2005-10-19 11:21
i second that. if you want to search, you bring in the radio application. What's the point of searching while in stand-by with the screensaver on - you want be able to see the frequency you tuned into, don't you?!
using the volume buttons to go through preset stations would indeed be more useful...
kristianm
Posted: 2005-10-19 11:35
Does SE listen to suggestions by email?
funtoosh
Posted: 2005-10-20 10:43
hey i tried it but it always shows NO CHANNEL FOUND... though there are 8 different channels available if u scan manually..
Funtoosh
max_wedge
Xperia Neo Black
Posted: 2005-10-20 12:07
on any scan radio that means signal strength is poor and the digital tuning can't hone in on the signal. You have to do it manually in such a case.
See if you can improve the postioning of the headset (stretch it out as much as possible) Other than that there is not much you can do....
knightrider
W960
Posted: 2005-10-20 15:29
My K750i does change channel presets when you hold volume up or down...
max_wedge
Xperia Neo Black
Posted: 2005-10-20 15:34
bizarre...
