flash menu's, no more searching :) |
Pochi Joined: Mar 06, 2008 Posts: 94 From: Saudi Arabia PM |
Yes!!
My w900i is now flashed!
Thanks for the help. |
ibanezman192 Joined: Mar 09, 2008 Posts: 1 PM |
I tried this to my W710i but the xs says that my phone is not supported is there another way? |
@ibanezman192
Try to use XS++ your phone might be supported on it. |
Shotgun Joined: Feb 12, 2008 Posts: 163 From: England PM |
On 2008-03-08 21:40:06, Kurayami wrote:
Yes!!
Np bro glad it worked for ya.....
IF I'm not mistaken the W710i is supported by "XS++" Make sure you have "XS++ v3.1 Darwin " to connect to your phone.
As for K850i users; we're SOL.
|AppleTV2|iPhone 12Mini 256GB|iPad Pro 256GB| Previously ... K750|Z500|Z520|K700|K790i|K850i, :Ericsson: T18z|T28World|T36m x3|T68m (Ericsson, not the rebranded T68i). |
reywal Joined: Oct 09, 2007 Posts: 99 PM |
if i install one or some of these flash menus, will it override/erase my default SE menu? My warranty is still active and im weary if doing this will avoid it. thanks
I am what my name says <<<<---------------------- |
ill1dan Joined: Feb 06, 2008 Posts: 9 PM |
Is this working on k810 phones? I uploaded some .swf files in tpa/...../flash with xs++ and then theme files with bluetooth, but i cant set none of them. I get "Theme corrupt. cannot be set." message.
Can someone help me with this? |
the k810 does not support flash themes
@ill1dan
You need to open the wanted theme with Theme Creator 1st so it converts it to the themes version that your mobile use, then you need to extract the theme file (.thm) using any zip program, then go to the theme.XML and open it using the Notepad then paste then collect the extracted files into any type of zip folders using the zip program then send it to your mobile.
not sure about the K810i if it supports the flash menus or not but that's how to do it (2 moves not just only uploading the .swf file but also what i mentioned above).
erichkooi Joined: Nov 21, 2007 Posts: 65 PM |
Hi, I am totally newbie.
Is this support for K850i set?
Sorry on my stupid question.
Eric |
the k850 supports flash themes, but the phone is not supported by xs++ so fas as it is a db3510
Hi Tranced.
That mean I unable to upload flash theme that posted in this thread?
How about SETool as I read they able to crack in the K850i folder structures? Maybe not yet, maybe in near future, i guess.
More info: http://www.esato.com/board/viewtopic.php?topic=165477&start=60
Thanks again for the info.
Eric |
@Tranced,
I knew k800 series doesn't support flash themes, but i thought this is some kind of mod...
@Kurayami,
Thx for the help but it doesn't work,
anyway i'll stick with the moded icons choise. |
meiso Joined: Mar 06, 2007 Posts: 63 PM |
Anybody know how to download the menus on this site:
http://se-team.com/load/13
I can't read whatever language it's in so I can't figure out which link is the download link, or if it's even possible to download.. If somebody could help it would be really cool. Thanks!
[ This Message was edited by: meiso on 2008-03-12 17:00 ] |
diabu Joined: Jan 31, 2008 Posts: 42 PM |
hello guys!
will this flash themes work on w910i? |
