Forum > Sony Ericsson > Software, Firmware and Drivers > flash menu's, no more searching :)
1, 2, 3, 4, 5  Next
Author flash menu's, no more searching :)
nocky
Posted: 2007-12-16 21:48
I have made this forum so lasy people can find menu's easier
I have searched the net for as menu flash menu's as possible and put them all into 1 file also most .thm files are with the apropiate .swf files, if not thats because i couldnt find the .thm file so you will have to make 1 to fit it.
The link below is a step by step image tutorial very easy to follow. size roughly 1.5MB (not created by me and i am not tyring to take the credit for it)
http://www.4shared.com/accoun[....]8/6ff22cbe/sharing.html?rnd=63
The link below is the flash menu's files size roughly 73MB (none of these menu's or themes have been created by me, and i am not trying to take credit for other peoples work these are menue/themes that are posted over then net)
(please let me remind you that i have not created any of this themes or tutorials and i am not trying to take credit for other peoples work)
also if theres is any menu's that i have missed could you post them here for others to download thanks
black w810i with super cam driver 8.54,
ToShaRa_Mega_AcoustiC_v1.5_high_quality_n_loud,
over 40 flash menu's,
flash wallpapers and screensavers and over 15 patches
[ This Message was edited by: nocky on 2007-12-16 20:49 ]
NightBlade
Posted: 2007-12-16 23:40
Thank you!
Posted: 2007-12-17 00:00
bookmarked
thanks nocky!
nocky
Posted: 2007-12-17 23:14
dont thank me thank the guys that made these if i find any more menu's i will post them here
love my k850i
w810i-black 8.54 super cam, toshara high quality n loud, over 40 flash menu's, flash wallpapers and screensavers.
Ricky D
Posted: 2007-12-18 11:33
Thanks for sharing after doing all the leg work to find this stuff. I've been looking for a way into flash menus for a while.
history: T610, W800, K610, K800, K850, S500, W760, T650, G900, C902, X1, C905 + Aino
www.wok-this-way.co.uk
k700 > Clara
Posted: 2007-12-18 12:19
Great work, but why cant i get these themes to work with my unbranded K850i. Are there no flash themes out there for the k850???????????????
Krzysiecw
Posted: 2007-12-19 21:20
How do set them ? I`ve copied thm and swf files into themes set up a thm file ... and the icons are still the same ... normal ... i`ve got k850i as well unbranded ...
[ This Message was edited by: Krzysiecw on 2007-12-19 20:23 ]
nocky
Posted: 2007-12-19 22:20
-1st install .swf files to phone by using xs++ v3.1 is easiest i think the link below
http://www.se-nse.net/gbrooks3/XS++/download.php
-install XS++ v3.1
-then turn off phone remove battery then put the battery back in and leave phone off
-open XS++
-click connect
-then hold c button whilst connecting your phone
-click fsx and wait a few minuts whilst all files load
-click tpa/preset/system/desktop/flash
-drag the .swf files into the right box
-then click shutdown then disconnect phone
-then put the .thm files to theme folder in phone
and now your new flash menu's should work:)
(i am not responsable for any damge that may happen to your phone)
hope this helps if you get stuck post and ill try and help:)
love my k850i
Duran
Posted: 2007-12-19 23:19
I've missed the whole thhing about all this flash menu
What is it exactly ?
nocky
Posted: 2007-12-19 23:24
flash menu's are a flash file(.swf) that are put into your phone to change your menu and they look like this
http://www.youtube.com/watch?v=qRtzrVT5Xbo
love my k850i
Duran
Posted: 2007-12-20 00:22
Ye but you could do that with k750 using far too ?
nocky
Posted: 2007-12-20 00:59
i think so, not sure tho
love my k850i
nocky
Posted: 2007-12-20 01:20
here is the xs++ tutorial on Flashing/GDFS-operations/Uploading files with XS++
http://forums.se-nse.net/index.php?showtopic=16148
i think this works with the k750 if you click the link it should say somewhere
love my k850i
Cold Fusion
Posted: 2007-12-20 02:08
k750/w800 does not support flash lite (swf) files dude
I BEING DIFFERENT
Previous Username: Ricky_bad420
cardsnk
Posted: 2007-12-20 07:36
do you have a tutorial for changing fonts? thank you for the files.
1, 2, 3, 4, 5  Next
