flash menu's, no more searching :) |
Duran Joined: Aug 25, 2006 Posts: > 500 From: Netherlands PM |
On 2007-12-20 02:08:26, Cold Fusion wrote:
k750/w800 does not support flash lite (swf) files dude
No but there were menu mods that achieved exactly the same thing as i see in the youtube video |
cardsnk Joined: Sep 11, 2006 Posts: 121 From: Philippines PM, WWW
please help with this one....please
http://www.esato.com/board/viewtopic.php?topic=161280 |
no worries i fixed it already. |
brorzan Joined: Jun 03, 2003 Posts: 114 From: PM, WWW
Iīve tried some of these themes and flashfiles, but I canīt make it work 100%.
I get flash-menus, but itīs not "full screen" in my T650i. Are all the files for phones with lower resolution or am I doing something wrong? |
Yes, of course there are flash menus for SE phones with lower resolutions. They need optimizing in Flash if you want them to work fullscreen. |
Thatīs good news, that means Iīm not totally hopeless! )
Is there anyone out there who got a lot of nice complete flash-menus that will fit the T650i?
I would like these themes complete with the swf-file från W880i: Citybeat, Musaic. |
DonJuan Joined: Jul 27, 2006 Posts: > 500 From: Las Vegas PM |
On 2007-12-19 22:20:02, nocky wrote:
-1st install .swf files to phone by using xs++ v3.1 is easiest i think the link below
http://www.se-nse.net/gbrooks3/XS++/download.php
-install XS++ v3.1
-then turn off phone remove battery then put the battery back in and leave phone off
-open XS++
-click connect
-then hold c button whilst connecting your phone
-click fsx and wait a few minuts whilst all files load
-click tpa/preset/system/desktop/flash
-drag the .swf files into the right box
-then click shutdown then disconnect phone
-then put the .thm files to theme folder in phone
and now your new flash menu's should work:)
(i am not responsable for any damge that may happen to your phone)
hope this helps if you get stuck post and ill try and help:)
this link doesnt work to upload the flash themes to my phone |
-install XS++ v3.1
-open XS++
-click connect
once i get here it always says failed, i dont get it, then it just disconnects my phone |
DB3150 (K850 and alike) are not yet supported. |
euqiddis Joined: Jul 23, 2005 Posts: 80 PM |
do these work on a k800i?
how much battery does it drain? |
i got this all sorted, it takes a while and some patience, the only problem is the lacl of 240x320 flash menus, i can only find a handful. |
So Nocky's 4Shared file contains no flash menus in 240x320 for the K850i ? I've found some AWESOME ones but have no clue if I can load multiple versions in my K850i ??? Can I?
|AppleTV2|iPhone 12Mini 256GB|iPad Pro 256GB| Previously ... K750|Z500|Z520|K700|K790i|K850i, :Ericsson: T18z|T28World|T36m x3|T68m (Ericsson, not the rebranded T68i). |
-install XS++ v3.1
-open XS++
-click connect
Well with XS++3.1 Darwin I don't get far as you can see.
On March 6, 2008 @ 12:43PM XS++3.1 Darwin Wrote:
12:36:51| Attempting to open the interface...
12:36:51|
12:36:51| TURN OFF PHONE!
12:36:51| Hold 'C' button on phone and connect phone NOW.
12:36:51| You have 30 seconds...
12:36:51|
12:36:52| Baseband ID: C802
12:36:52| Protocol Version: 4.1
12:36:52| Warning: IMEI name does not match GDFS name (IMEI:NULL GDFS:K850)
12:36:52| ...using GDFS name
12:36:52|
12:36:52| Profiling SEMC phone...
12:36:52| Platform: DB3150
12:36:52| OTP CID: 52
12:36:52| EROM CID: 52
12:36:52| EROM Color: Red
12:36:52| IMEI: 35182902xxxxxx
12:36:52| Phone ID: K850
12:36:52| Region: ROGERS
12:36:52| CDA: 1202-7829 R4A
12:36:52| Firmware Version: R1DC001
12:36:52| EROM: 1200-4341 SEMCBOOT R6A008
12:36:52| Ready for operation!
12:37:51| After making any changes with FSX
12:37:51| you must press the 'Shutdown' button
12:38:08| Sorry, your phone is NOT SUPPORTED
12:38:08| Error: FSX failed.
12:38:08| FSX Shutdown!
12:38:10| Disconnected
Pochi Joined: Mar 06, 2008 Posts: 94 From: Saudi Arabia PM |
Ok this point i couldn't understand.. how can i put the .thm file in my phone? using xs++ or by simply sending the .thm file to my phone while it's ON? |
Shotgun Joined: Feb 12, 2008 Posts: 163 From: England PM |
The .SWF file with XS++ & the .thm file straight to the phone whilst the USB cable is connected & phone is on & simply copy/paste into the Themes folder
