Sony Xperia Rumours 2018 |
Archdragoon Joined: Mar 18, 2015 Posts: > 500 PM |
On 2018-02-16 15:34:17, Tejstar wrote:
Not sure where all this 'Pro' talk came from.
There will only be two new phones launched - Xperia XZ2 and Xperia XZ2 Compact. Fact.
Oh...
Device : Xperia 1 II Headphone : MDR-M1ST + MUC-S12SB1, ATH-DSR9BT, WH-1000XM4 DAC/AMP : PHA-2A |
Fisher Joined: Sep 05, 2017 Posts: 50 PM |
XZ1 5.2"
XZ1C 4.6"
XZ2 5.7" 152,8x72,4mm
XZ2C 5" 135,4x64,6mm
Makes sense
[ This Message was edited by: Fisher on 2018-02-17 10:18 ] |
ascariss Joined: Apr 06, 2013 Posts: > 500 PM |
On 2018-02-16 07:50:23, XperiaJunkie wrote:
What I find strange is the fact that Sony haven't even teased us with anything yet, normally there's some kind of cryptic trailer or at least a hint at what to expect but we've had absolutely nothing.
If I recall similar situation last year, I checked the previous rumours thread for teasers and all I found is this
https://www.esato.com/board/ui/65Z890Bw5oTZ6R94Q7QQ.jpg
Sony also sent out MWC invites last year
http://www.xperiablog.net/201[....]ile-mwc-2017-press-conference/
I am sure they did this year but i can't find any leaked photos of the invites personally. I am sure it is out there.
The only mention of their press conference I found on personally was on a polish xperia site. Doing a reverse image search does yield the invite on several other sites.
http://www.portal.xperiasite.pl/sony-zaprasza-targi-mwc-2018/
Basically it says, we invite you to come and see the new innovations of Sony mobile. We'll see you at MWC 2018, Monday, Feb 26 at 8:30, entrance 8:15, Sony Booth, Hall 3, Fira Fran Via, Barcelona.
This is the rules for FCC fillings, via the change in filling name submission,
https://www.law.cornell.edu/cfr/text/47/2.933
§ 2.933 Change in identification of equipment.
(a) A new application for certification shall be filed whenever there is a change in the FCC Identifier for the equipment with or without a change in design, circuitry or construction. However, a change in the model/type number or trade name performed in accordance with the provisions in § 2.924 of this chapter is not considered to be a change in identification and does not require additional authorization.
(b) An application filed pursuant to paragraph (a) of this section where no change in design, circuitry or construction is involved, need not be accompanied by a resubmission of equipment or measurement or test data customarily required with a new application, unless specifically requested. In lieu thereof, the applicant shall attach a statement setting out:
(1) The original identification used on the equipment prior to the change in identification.
(2) The date of the original grant of the equipment authorization.
(3) How the equipment bearing the modified identification differs from the original equipment.
(4) Whether the original test results continue to be representative of and applicable to the equipment bearing the changed identification.
(5) The photographs required by § 2.1033(b)(7) or (c)(12) showing the exterior appearance of the equipment, including the operating controls available to the user and the identification label. Photographs of the construction, the component placement on the chassis, and the chassis assembly are not required to be submitted unless specifically requested.
(c) If the change in the FCC Identifier also involves a change in design or circuitry which falls outside the purview of a permissive change described in § 2.1043, a complete application shall be filed pursuant to § 2.911.
So with Sony removing the filling, it means the design, circuitry or construction has changed. So this could be anything basically. lol. |
astider Joined: Jan 21, 2018 Posts: 61 PM |
According to last year's MWC invite, I think it tell us color of XZ Premium (Luminous Chrome) and its loop theme.
Wondering what is this year invite telling us. Maybe water drops theme like XA2/XA2 Ultra, new color and ... new screen ratio (imply by picture ratio) ?
EDIT: just cropped the picture and scaled it... the ratio is perfect 21:9... seriously?!
[ This Message was edited by: astider on 2018-02-16 16:25 ] |
justus333 Joined: Apr 21, 2007 Posts: 163 PM |
Cant you just leave ADIDA alone at last? Its almost like a witch hunt. As much as he may sometimes err when it comes to his "inside" infos, he never insults anybody, contrary to some others here...... |
About the water drops.... Stronger slow motion maybe?
It reminds me of this ... XZs
https://i2.wp.com/www.9to5net[....]/2017/02/Xperia-XZs.jpg?w=1104
Something else.. BACKGROUND DEFOCUS was renamed. Now is called BOKEH.
[ This Message was edited by: Moe87 on 2018-02-16 20:42 ] |
Hopefully the bokeh make by new flagship will be better
Here's the English version of the invitation
I think the picture used in the invitation is one of the wallpapers in the flagship model. I'm expecting something big here, but I'm afraid that I'll be disappointed when they announced it. See this MWC 2017 invitation of XZP's wallpaper.
I have to get this out of my system, though: They called themselves innovative, but this year, they used basically the very same words as last year's MWC 2017 invitation.
[ This Message was edited by: AlvinZahranM on 2018-02-17 14:34 ] Daily Drivers: Galaxy S23 Ultra, Galaxy S22 Ultra, and iPhone 14 Pro Max Secondary: vivo X80 Pro Still using as a backup: Xperia XZ2 Still using (not as much): Galaxy Tab A 8.0 |
Shino03 Joined: Dec 22, 2008 Posts: > 500 From: Pearl of the Orient Seas PM |
I do hope Sony will up their game this time. Since Xperia Z they have been cutting down their RnD and marketing for mobile year after year. I hope they can take more risk this year.
[ This Message was edited by: Shino03 on 2018-02-17 06:01 ] |
XperiaJunkie Joined: Dec 13, 2012 Posts: > 500 From: Parts Unknown PM, WWW
There's new stuff over at the FCC, not sure if there's anything worth looking at however.
I'm so happy 'cause today I've found my friends ... They're in my head
blackzeros Joined: Jul 21, 2015 Posts: 381 PM |
i think they changed something circuit level for dismissed device , resend test reports to fcc.
mrand Joined: Feb 05, 2018 Posts: 7 PM |
Is that based on any specific insider info?
If the FCC is like any other regulatory certification, it could be as something as simple as changing the name. Or maybe you're right. Perhaps ear phone jack. Or change of radio's. Or no telling what else. |
Resubmission could mean any of these "change in design, circuitry or construction". So unless blackzeros knows something, the design change could be anything. |
RacSony Joined: Mar 24, 2017 Posts: > 500 PM |
One thing confirmed here is nothing externally changed, and 3.5 headphone jack is still gone.
https://sumahoinfo.com/5-7inc[....]-xperia-xz2-xz-pro-xz1-premium |
Not a surprise. If 3.5mm is missing it, re-engineering the device to add one in would have involved a lot more time and I doubt a new fcc filling would have been done so quickly.
I guess a MWC reveal is still likely then? |
