Sony Xperia Rumours 2018 |
josephnero Joined: Mar 20, 2012 Posts: > 500 From: Sanford North Carolina USA PM |
Np buddy |
New Compact With 18:9 Screen=Real Compact
Coming Soon H1 2018 and Standart Compact 16:9 Screen maybe IFA |
ascariss Joined: Apr 06, 2013 Posts: > 500 PM |
On 2018-01-18 19:36:19, Moe87 wrote:
@ascariss maybe it is one phone for MWC, because it says January 17th..
Ok correction, it was not a phone, but a wireless headset, PY7-37030I
A second one also appeared 2 days later, PY7-13007N. so they might be sony mobile wireless headsets, perhaps like the apple wireless airpods.
That being said, another phone appeared PY7-21831A. This appears to be the MWC device I feel looking at the dimensions and label location, label comes out of the top and not the side.
here are the dimensions from the documents
overall length x width - 152.79 mm x 72.42 mm
overall diagonal - 165.695 mm
screen diagonal: 145 mm - 5.7 inches
XZ Premium for comparison
overall length x width - 156 mm x 77 mm
For comparison, the G6 has a 5.7 inch screen, so bezel wise, we are looking at something similar to the G6 with a bit more bezel.
LG G6: 148.9 mm x 71.9 mm, the sony would be about 4 mm taller and 0.6 mm wider.
Time to calculate the screen to body size. Assuming we are looking at a 18:9 screen we can use Pythagoras to calculate the sides. (hopefully my math is correct)
a^2 + b^2 = c^2 (a=18x, b=9x, c=145)
(18x)^2 + (9x)^2 = (145)^2
324x^2 + 81x^2 = 21025
405x^2 = 21025
x^2 = 51.913580246913580246913580246914
x = 7.2051079274993223550962262659119
Rounding off, x = 7.21 mm
so screen size is, 129.78 mm x 64.89 mm
area of screen is = 8421.4242 mm^2
area of body is = 11065.0518 mm^2
screen to body ratio = 76.1%
This does seem kind of low but is within 2% of the G6, but still better than the current XZP of 68.4%. I made a quick image using the dimensions of body and calculated screen, it doesn't look great at first but the image is only giving a rough estimate, the real device will have curved corners and sides and so forth, making the bezels seem less.
18:9 - 76.1% screen to body ratio
16:9 - 81.2% screen to body ratio
[ This Message was edited by: ascariss on 2018-01-20 18:43 ] |
Wow, 81% Bezel is Amazing |
Subhamstylo Joined: Nov 20, 2017 Posts: 93 PM |
Look like we are going to see non existent side bezels Like XA2..
But top and bottom bezels will be bigger than competitor if the dimensions are true!
Let's see what happens!!
Xperia XA2=75% Bezel
This XPERIA=81% Bezel |
ASCARISS
LG G6 18:9 format Screen and Sony's New Flagship With 16:9 fotmat Screen, Sony's Sizes=Amazing.... and, is not Fake 5.7 inch like LG G7 |
tk007 Joined: Dec 13, 2012 Posts: 173 PM |
R u insane he said we'll see bit more bezel than lg g6 and lg g6 is 78% bd ratio and how 5.7 inch or 5.4 screen acording to u is 81% bd ratio in 152 dimension ! |
He is using a 16:9 ratio for the screen, I used a 18:9 for my first calculation, I have updated an image with 16:9 which leads to 81.2%
It is uncertain which ratio sony will use, this "leak: shows 16:9
http://www.xperiablog.net/201[....]s-be-the-next-xperia-flagship/
but the dimensions for this new device and the leak are different.
[ This Message was edited by: ascariss on 2018-01-20 18:54 ] |
Edge to edge design increases the screen/body ratio.
That is why XA Ultra has 75-76%.
Can someone please edit a XA1 and make it 5.7" 16:9 screen and dimensions of new phone?
So we can see how it looks..
I know design is probably not same, but just for curiosity.
Note 5 is 5.7".
Body is 15,32 cm x 7,61cm
Not sure if my calculation is right.
Top/bottom bezels would be 1,3 cm each.
[ This Message was edited by: Moe87 on 2018-01-20 18:56 ] |
Glyptho Joined: Oct 29, 2017 Posts: 24 From: Canada, Quebec PM |
Based on outside dimensions the rounded corner would be of radius 3.75mm.
If screen is in 16:9, side bezel would be of 0.67mm and up and lower one would be of 13.21mm
If screen is in 18:9, side bezel will be of 3.79mm and up and donw one will be of 11.55mm
Second scenario seem more plausibe |
The sony will have ~81% stbr and g6 has 78.6%.
G6 has 19.4 mm combined top and bottom bezels and the sony phone will have 26.6 mm t-b bezels.
G6 has 7.15 mm left and right bezels, and the sony phone will have 1.44 mm side bezels, which is incredible.
The new sony phone will maintain its dual stereo speakers from the last generation, and there will be a sony logo on the front, too. That's why the top and bottom bezels are a bit thicker than its competition.
Then, like previously announced phones, the fingerprint scanner is also moved to the back, that's why they could make the side bezels very thin.
[ This Message was edited by: AlvinZahranM on 2018-01-20 19:03 ] Daily Drivers: Galaxy S23 Ultra, Galaxy S22 Ultra, and iPhone 14 Pro Max Secondary: vivo X80 Pro Still using as a backup: Xperia XZ2 Still using (not as much): Galaxy Tab A 8.0 |
81%
[ This Message was edited by: tk007 on 2018-01-20 18:53 ] |
blackzeros Joined: Jul 21, 2015 Posts: 381 PM |
https://fccid.io/PY7-21831A/R[....]10-S1V3-FCC-Report-SAR-3721463
http://phonesabout.com/screen[....]lculator-for-smartphonetablet/
almost %81 but width dimension is a little weird if it's a 16:9 screen , 5.7 inch screen itself has 71 mm width. |
Yes, it is weird, but they might curve the phone and its screen a bit to increase the stbr, like pixel 2 xl or s8.
