Upload Java Games to D500 |
Chazzer3 Joined: Mar 23, 2004 Posts: > 500 From: Edinburgh, UK PM, WWW
Can u send video's tho??
Swag Joined: Jun 21, 2002 Posts: > 500 From: Oslo, Norway PM |
Yepp!
Phew!
I thought for a second there all the vids I'd made for my E720, arriving on Wednesday would be stuck on my pc!
dragonrage Joined: May 31, 2005 Posts: 1 PM |
for how to install games via bluetooth go here http://315.fiberworld.nl/d500/
for d500 games go here
www.d500world.tk |
C4nn0n Joined: Jun 02, 2005 Posts: 1 From: hungary PM, WWW
Hi
What are Serial Java download's and Serial Java menu's codes on E720? Becasue the D500's codes don't work. Or How i can upload java games to my E720 via Bluetooth? |
pozygal87 Joined: Jun 07, 2005 Posts: 1 PM |
i tried following the first bt guide bt i got stuck at the part where it says u shld have an unauthenticated thingy... what shld i do? i reinstalled alot of times already. (or is it redid?) |
rorza Joined: Jul 14, 2005 Posts: 17 PM, WWW
Where is the 'uploader.exe' program ?? How do i install it or find it ?? I have Softick ver. 2.21 and have got so far untill now. Plesae help - anyone !! Thanks |
Marshes Joined: Jul 24, 2005 Posts: 1 PM |
Hey D500 Guru, quick question I have an sgh-e638 kindda the lighter version of the D500, but it doesnt have bluetooth so im trying to getit connected through IRDA but after I serial enable my phone then enter the PPP UP menu it goes white a few seconds and reboots, but my proxy settings seem to be disabled on my phone side. Any ideas? |
alex2751 Joined: Jul 22, 2005 Posts: 40 PM |
I have sold my D500 since there is not much of java games anyway and to send them from PC is annoying. |
swatjosh Joined: Mar 18, 2006 Posts: 1 PM, WWW
Weres this Java uploader ? The link dont work |
D500 GURU Joined: Apr 11, 2005 Posts: 6 From: Glasgow in Scottyland ;P PM |
Hey guys sorry i forgot about this thread aaaaaaaaaaaages ago...yeah about the irda on that other fone...unless its a d500 i seriously doubt it'll work due to the encryptions samsung uses...the irda code may not have enuff info availlable to it to send the games as they can be reely quite complex sometimes...also u may wanna try just connecting ur fone thru the norm program first then using softick ppp cos i know sometimes ur fone needs to be fully connected before it runs properly....as far as files like the uploader go...http://www.mobileplayground.co.uk/d500gamesinstall.htm...this site has all files necesary and also an illustrated version of the instructions hehe. ENJOY
CJ |
jessi_ep Joined: May 18, 2006 Posts: 2 PM |
i'll have foolw this instructions...guide to transfer games to d600 via bluetooth
1) Open “My Network Places”
2) Click “View Network Connections”
3) Click “Create a new connection”
4) “Welcome to the new connection wizard” click next.
5) Click “set up an advanced connection” and next
6) Click “connect directly to another computer” and next
until step no. 6 no prob.>>. in step no. 7 when i click “host” my comp. freeze then error….
can anybody help me pls.....
how can I solved this prob ....?
thanks b4
JJ! Joined: Sep 13, 2005 Posts: > 500 PM |
Put games on samsung phones like this:
Create jad file from the jar file using jad maker (freeware)
Then go here:
http://www.euploader.com/index.php?action=upload
Upload the jar file (ignore the id number you get at this point)
Then you will be asked to upload the jad file - do so
You will then be given an id number and password. Go to the wap address provided on your phone and put in the numbers.
Then game will then be downloaded on to your phone. |
sorry, i asked for install java via BT not via wap.....
thanks..
harpreet1433 Joined: Dec 25, 2006 Posts: 1 PM |
i have developed a appication.
it works fine on toolkit wtk.but as soon i deploy it on samsung d500 it does not support images
i have tried all the formats of images ie .png,jpg,gif.
but samsung d500 does not display them
but the application works fine on nokia
this application is not devloped keeping in mind any mobile specific but is general
can smone from j2me tell about the problem with d500
to create image i used code:
Image img=Image.createImage("/images/red.png");
thanks |
