Mpegable X4 live |
Kwiksta Joined: Jul 17, 2004 Posts: > 500 PM |
In mpegable x4 live, when you convert a video, is there an option, where you can select fro what point you want to starts converting e.g. the 5th minute
Many Thanks |
c'mon guys? |
c'mon dudes, all i wanna know, is there a program or an applet (sam thing) that you can use to cut movie files short? |
nishantmohan Joined: Jun 27, 2005 Posts: 4 PM |
u can change the set in and set out points in the "video preprocessing window" in settings |
Cornholio_666 Joined: Nov 30, 2004 Posts: 198 From: London PM |
yes there is an option, you go to video preprocessing, on In/out point click user defined. in the first box you set the point where you want it to start, and the you press the set in-point button. you do the same in the next box if you want to cut off the end too.
Queens Of The Stone Age RULE! Also known as "THE ROADIE" Burn The Witch "I find that on the internet, everyone's very tough in an anonymous, pussy sort of way'" - Josh Homme. March '05 |
darky Joined: Jun 14, 2005 Posts: 299 PM |
what they said
in point for start out point for end
PlainShane Joined: Jul 24, 2005 Posts: 29 From: HoFo PM, WWW
Be sure to press the corresponding buttons next to the text box where you input the time to set it. It automatically adds a 23th of a second for a buffer though. |
