K700i frames |
j4sp33d Joined: Aug 06, 2004 Posts: 70 From: Philippines PM |
hi guys. i upgraded my K700i to R2L version here in Manila a week ago and here's what i have observed with regards to the missing frames issue. when i access my camera i have the following frames: double heart, extra, hiphop, hippie, monkey, superhero, tv star and wanted. are these also the frames you have on your phone? i seem to have more frames when my phone was still in R2A. i don't know if the upgrade to R2L took out a few other frames. anyway, every frame works fine except for the double heart. the double heart frame doesn't show after you take a picture.
there's also another frames feature when you edit pictures (go to more->use->edit->tool->add frame). the add frame is disabled if the picture you are editing is not 160 x 120 in size. i then tried to edit a 160 x 120 picture but when i select the add frames option the phone will display "no more files." i haven't accessed this add frames before when my K700i was still in R2A version so i don't know if there are frames in that option. i also did a couple of master resets on my phone since i got it so i'm not sure if they were deleted permanently. can you guys pls check your K700i if you also had a similar experience with the said frames. thanks.
WilliamB Joined: Aug 27, 2004 Posts: 23 PM |
@j4sp33d
On my K700i running R2L I've got 21 different frames under the camera function and 9 different frames when doing an editing as you mention. The frame Double Heart works fine.
You need a format and full reinstall of the software. A flash will not fix your problem.
[ This Message was edited by: WilliamB on 2004-08-29 13:38 ] |
My SE K700i now having the stock R2A . . . firmware has more frames than you just made mention in your upgradefone . . . About the twin-hearts frame, I guess you'll be needing a 'twin-faced-pic' in order for it to materialise Just kidding here mate  |
really? that's a lot of frames. did you have all those before when your K700i was still R2A? what frames do you have in camera mode? how about in editing mode? what language pack do you have in your K700i? mine is taiwan. do you have any idea how i can get back my missing frames? |
Maybe you just have to 'downgrade' your firmware back to the R2A . . . software again dude just in order to have those 'cpmplete' set of frames - again As I have read in the past, the R2L . . . firmware is not a 'flawless' upgrade, yes, it can improve the battery life of your fone plus eliminate majoirty of the bugs, though I guess it has some downsides too, just like what happened when you lost some of your frames here pal . . . ! |
@j4sp33d
I don't have the time to write down the names of all 21 plus 9 frames, sorry! My language pack is EU4 and software version R2L001.
[ This Message was edited by: WilliamB on 2004-08-29 13:41 ] |
williamB:
thanks for the replies. i'll just wait for the next version to come out. i hope it gives me back my missing frames. i'm pretty much satisfied with the benefits i got when i upgraded to R2L. i've read in some posts that some R2L versions are incomplete or have corrupted files. some users report that their phones hang up when they access the frames feature in the camera. some even can't play the tennis game. so far i haven't experienced any of these reported bugs in the R2L version except for the missing frames which fortunately does not make my phone hang up or reset on its own. |
@j4sp33d
The 21 frames in the camera function:
-Angel
-Baby
-Behind Bars
-Bunny
-Double Heart
-Extra
-Hiphop
-Hippie
-Monkey
-Superhero
-TV Star
-Wanted
-Amber
-Brass
-Brushed Alu
-Bubble
-Camo
-Jelly
-Mediterranean
-Soccer
-Wriggle Plant
The 9 frames in the edit function:
-Amber
-Brass
-Brushed Alu
-Bubble
-Camo
-Jelly
-Mediterranean
-Soccer
-Wriggle Plant |
thanks williamB! now i remeber that i had those frames you mentioned when my phone was still in R2A although some frames are just repeated in the picture editor. i'm beginning to like the frames feature in the camera mode. my friends enjoyed how they looked with the frames. any idea on how do i get back the missing frames? |
williamB:
i read your reply in my other post. btw what's the difference between format, full reinstall and flash? what service centers usually do when you request for an upgrade is flash right? do all service centers do a format and full reinstall? do they need to download a new R2L version for my language pack? |
baste07 Joined: Nov 07, 2002 Posts: > 500 PM |
i have a firmware of R2L and i have 21 different frames.. and i don't know how many was there before coz i didn't used it before anyways
is it really that important? having more frames? |
@j4sp33d
If you flash the phone, then the software is updated, but missing files wont be reinstalled. If you get a format with reinstalled software, then all the files is reinstalled to your phone.
Since you have missing files, you need a full reinstall to get the frames. Next update will probably not reinstall the frames for you unless you do a full reinstall.
It takes a little longer to reinstall the software than to update it (an hour or so).
[ This Message was edited by: WilliamB on 2004-08-29 17:30 ] |
baste07:
hi. thanks for the reply. i think the missing frames is not that of an issue but i think if key files in the R2L version is missing then that should be of concern. i have been reading that some users who upgraded their K700i with R2L don't only complain of missing frames but also their phones hang or restart automatically. anyway i'm hoping that i'm only missing some frames and not key files that the phone requires to work normally. so far i haven't encountered any auto restarting or hang issues. |
zw4mp Joined: Aug 16, 2004 Posts: 7 PM |
eeh, my k700 reboots when i enter the frames menu.. i have never seen them :/ can this be fixed in r2l u think? |
ezhil Joined: Dec 06, 2004 Posts: 4 From: Chennai PM |
Hi,
In my K700i, in the phoneMenu I'st two icons Occasionally missing or disappears (i noticed this problem i my common use) when i try to navigate the icon to that position then it gets displayed or appears back when i move back the cursor to some other menu it disappers back . After some time the phone gets switched off automatically. Or else if i try to do some operation it restarts automatically. when i tried to contact the service center in chennai they updated my firmware with R2AA & finally they swapped the instrument twice but still the Persist , Finally i received an replacement of new handset from them. I was the new SE K700i for the past couple of week, But even with the new one i faced the same icon missing problem once. Whats wrong is it a common issue with K700i.
[ This Message was edited by: ezhil on 2005-02-22 10:38 ] |
