Forum > Sony Ericsson / Sony > Accessories > Where to get a T65 Battery
Author Where to get a T65 Battery
jcwhite_uk
Sony Xperia T
Posted: 2004-08-20 11:55
Does anyone know where I can get a replacement battery for a T65? I am ok changing it myself but cant find one anywhere. I have used the seach but couldnt find anything.
*Jojo*
Nokia C6-01
Posted: 2004-08-21 06:44
Try ebay dude
dislexican
T630
Posted: 2004-08-21 06:46
Ebay is god. I've gotten everything I needed from there and cheap.
*Jojo*
Nokia C6-01
Posted: 2004-08-21 06:56
But I just doubt it if the author will be going for the originals As he made mention that he's only after for 'replacement' or class A ones !
BobaFett
Posted: 2004-08-21 07:35
I never saw t65 batts for sale, the only solution imo is to ask se. But not sure if they have still for sale. U should contact the se hq and ask them for help.
xbcrguy182x
T226
Posted: 2004-08-28 02:34
You can search on Froogle. Thats my ebay alt.
msnr
Posted: 2004-09-13 14:12
They have them at www.irwebonline.com
BobaFett
Posted: 2004-09-13 15:28
Are they selling original ones? Tia
jcwhite_uk
Sony Xperia T
Posted: 2004-09-13 15:36
I just had a look at that site. All the batteries are not original and I couldnt find one listed for the T65.
BobaFett
Posted: 2004-09-13 16:58
Dont go for non-orig batt, just suffered with one. The t65 batt was one of the best and most stable.
spuddle
Posted: 2004-09-17 01:03
i once had a t65, it broke, so i took it apart, and inside it doesnt have a convensional battery like most phone, its kind of "built in" and not ment to be replaced, it isnt in a solid cover and the most strangest thing ive ever seen!
jcwhite_uk
Sony Xperia T
Posted: 2004-09-17 02:01
Is it anyything like the bat from an A2618?
BobaFett
Posted: 2004-09-17 09:11
U mean if it looks like that? No, its more like a t610 batt, but a bit bigger.
ovidiugm
P800 no flip
Posted: 2004-09-18 17:10
Well, the battery has no contact connectors like a usual one, but it is directly soldered through two flat metal bands. The manual mentions that the battery is not replaceable, so I don't think you'll find an original one (or even third-party, as the changing process implies soldering & stuff).
You should ask in service shops for it, as it may be considered serviceable part/component
BobaFett
Posted: 2004-09-18 18:08
Was at my service man today, he suggested to buy another fone, asked some insider ppl, no reason for a new batt. Sorry.
