Help with W960 screen calibratio |
omaho Joined: Jul 21, 2005 Posts: 2 PM |
hi!
I've just encountered a probllem with my w960. The screen calibration is off...way off...so far off in fact that when I try to cre-calibrate the screen I'm not able to press the circles as when I try to press the first one it says that i'm too far from the circle. Problem is that if i'm to compansate for the screens horrible calibration i'd have to press outside of the screen. Does anyone have any idea what I could do to fix this? |
nfts-pstrfs Joined: Jul 16, 2007 Posts: 43 PM |
try updating or reinstalling the firmware. that should fix this I think
tranced Joined: Jan 19, 2006 Posts: > 500 From: Sto. Dgo., Dominican Republic PM |
I suffered the same with my p990. I updated it using SEUS and i thought it'd fix the problem. It didn't
Then i started to believe it was a problem with the touchscreen.
Can you say service center.
LFO Joined: Apr 24, 2007 Posts: 1 PM |
Hi
Twice my calibration went - used the phone calibration, firmware & reset but did not work.
BUT the way i fix mine was simple - i slapped the back of the phone into my other hand very hard and it fixed it (2 times now).
Problem solved itself...for two days....now my screen won't respond to touch. I'm guesing the digitizer died. Someone know how to replace? Service center is not an option as they keep my phone for 3 weeks to a month before fixing it... |
check this out: http://www.formymobile.co.uk/w960disassembly.php
it's a disassembly guide
