K800 or K750 Cam Modul on W610. |
PSY®Torjan Joined: Jul 20, 2008 Posts: 9 PM |
Hey there guys Will the k800 or k750 cam modul fit in the w610 cam socket
i wanted to try it out. |
afaik this cant be done. you can have the k750 cam module in the w800 and w810. dont know if it can be done with others.
razec Joined: Aug 20, 2006 Posts: > 500 From: Mars PM |
k800 uses sony MCB880 and k750 uses sony KNC201. both modules are completely different hardwares in contrast to w610's sony mcb750 camera. in other words, its impossible to fit the first two modules on the latter. also take note that the phones have different drivers as well
10 years at Esato |
this was enough
Thanks guys for ur replys, now i know the diffrence between the cam module. Thanks very much |
