C902 on T-Mobile |
J-J Joined: May 10, 2004 Posts: 268 From: Nottingham, UK PM |
Hi guys,
Any chance that this phone can be unbranded even if it isnt unlocked?
Cheers |
aremaboy Joined: Nov 27, 2004 Posts: > 500 From: Malang, Indonesia PM |
www.davinciteam.com
www.kulankendi.com
www.totalgsm.org |
Cheers for that.
I know they can be unbranded, i just didnt know if they needed to be unlocked first.
Also does unbranding wipe all the data on my phone and will it allow me to delete protected files? |
You can debrand this phone if it is locked and it will still be locked after the debranding.
I debranded a locked 3UK branded C902 and had to get it unlocked afterwards.
[ This Message was edited by: goldenface on 2008-10-02 10:51 ] |
totalgsm Joined: Jan 12, 2007 Posts: > 500 From: totalgsm.org PM, WWW
On 2008-10-02 11:50:36, J-J wrote:
Cheers for that.
You will lose all data that is on the phone memory , the ones in the memory card will be safe.
