Forum > Sony Ericsson / Sony > Software, Firmware and Drivers > Pocket Inclinometer - new software from DPsoftware, try it now!
Author Pocket Inclinometer - new software from DPsoftware, try it now!
sblantipodi
Satio Black
Posted: 2008-05-31 16:19
DOWNLOAD IT HERE!
Pocket Inclinometer is a JavaME technology-based inclinometer
capable of measuring the inclination of a flat surface.
Thanks to a specific calibration function,
Pocket Inclinometer is able to calculate the possible inaccuracy of the motion sensor
and to maximize the accuracy of the measurements.
This is fun software product with eye-catching graphics that may be useful in various situations.
The software is compatible with all phones equipped with JSR226 for vector graphics
and JSR256 for managing accelerometer.
W910, K850, W760, C902 runs this software smoothly
I hope you like it
DPsoftware.org - http://www.dpsoftware.org
[ This Message was edited by: sblantipodi on 2008-05-31 15:20 ]
[ This Message was edited by: sblantipodi on 2008-05-31 15:21 ]
[ This Message was edited by: sblantipodi on 2008-06-22 22:36 ]
sblantipodi
Satio Black
Posted: 2008-06-03 13:00
A youtube video with the software in action:
http://www.youtube.com/watch?v=V-CsoHxeaSE
[ This Message was edited by: sblantipodi on 2008-06-03 12:04 ]
Supa_Fly
Posted: 2008-06-03 20:29
Works with my K850i very well - its branded too
However, ZERO is on the right side of the display when held vertically - or normal - I'm sure its accidentally set to landscape display.
sblantipodi
Satio Black
Posted: 2008-06-03 20:37
this is perfectly correct...
you should flip your phone horizontally to mesure...
sblantipodi
Satio Black
Posted: 2008-06-10 15:54
I'm curious to see this software in action on a C902...
No one has preordered a C902?
Download FPC Bench a good benchmark/system info for your phone.
Download Pocket Inclinometer for your phone's accelerometer.
sblantipodi
Satio Black
Posted: 2008-06-18 17:01
probably you'll see this software on SonyEricsson Fun&Downloads section soon...
jcwhite_uk
Posted: 2008-06-18 17:44
Any chance of a version for Nokia S60v3?
Supa_Fly
Posted: 2008-06-18 18:15
Considering its J2ME it should work - however the calls to the JSR's may be different.
jcwhite_uk
Posted: 2008-06-18 18:21
Didnt work on my N95. Just said it wasnt compatible.
sblantipodi
Satio Black
Posted: 2008-06-18 18:38
this is normal because your N95 doesn't support JSR256...
sblantipodi
Satio Black
Posted: 2008-06-18 21:05
probably I'll release a S60 version in the feature.
sblantipodi
Satio Black
Posted: 2008-08-10 23:46
Newer SonyEricsson support added
Domecot
Apple Iphone 5
Posted: 2008-08-10 23:49
does it work on k800i?
sblantipodi
Satio Black
Posted: 2008-08-10 23:51
no, k800 has no accelerometer...
sblantipodi
Satio Black
Posted: 2008-09-16 16:57
tested on a pre C905.
