Handsfree Answering |
gooner23 Joined: Jan 21, 2002 Posts: 51 From: Matthew Raymond PM |
Cannot get any headset on my T68 to auto answer. I thought the problem was my HBH-20 bluetooth set, but now I have tried a regular HBH-10 and that will not work either. What setting am I getting wrong?? Help please. Thanks Matthew |
john74 Joined: Dec 21, 2001 Posts: > 500 From: GREECE/AUSTRALIA PM, WWW
go to the setting menu voice dialling and check the handsfree option with the # key as soon as you add voice commands first,magic word,voice answer etc
jh67 Joined: Nov 30, 2001 Posts: > 500 From: denmark PM, WWW
Matthew :
I guess you're talking about, if the phone rings,..it should transfer the call to the headset, right ?
go to :
Settings > handsfree > answering mode >
Set to "automatic"
This works for me with the HBH-10 and T-68.
And the bluetooth-mode can either be "ON" or Automatic",..doesnt matter in this case
Jan
Marc Obermann Joined: Feb 08, 2002 Posts: 5 PM |
having spoken to Sonyericsson i can confirm whilst using a bluetooth headset magic word & voice answering does not work. Voice dialling works by pressing the button on the headset and then speaking. Magic word & voice answering only work with personal handsfree physically attached to bottom of your phone. YES i also feel cheated at the reduced options with bluetooth headset. |
@jh67
Yes I have tried this but it does not work. Seems to auto answer when I use the hands free on my radio hands free but not HPB-10 OR HBH-20
[ This Message was edited by: laffen on 2002-02-09 19:16 ] |
mms Joined: Jan 14, 2002 Posts: 67 From: Netherlands PM |
Gooner:
To my info it is not possible to automatically ANSWER (eg: after 2 rings) a call using the hbh10 (first Ericsson Bluetooth headset). Your phone can only automatically TRANSFER the call to your bluetooth-headset, but you still have to press the little button at your ear to "ANSWER" the call.
Indeed, magic-word doesn't work either. This would require that the headset listens to whatever you say, and "wakes-up" after the magic-word. This is not the case (IMHO) with the hbh-10 (you'll have to push the little button)...
Jan: I don't think that your mentioned setting has influence on the hbh10/20. That specific setting is only relevant for the wired personal headset...
Hope this sheds some light...
MMS |
mr beeb Joined: Jul 29, 2002 Posts: 85 PM |
I feel cheated too.
I have been greatly disappointed to discover that to answer calls with models of headset such as the Nokia Wireless Headset HDW-1, and the Ericsson HBH 30 Bluetooth Headset (and all others, Plantronics etc) one has to be able to raise ones hand to the "answer" button on the headset. Surely it wouldn't be difficult to design (or modify) the mobile phone and/or headset so calls can be answered by voice without having to physically press the answer button on the headset? Or why can't you press the answer button on the phone to wake the headset, eliminating the need to raise your arm to press the button on the headset? Sounds simple doesn't it? But why have manufacturers not thought of it? And when people like me have raised it with them why has there has been a deafening silence?
I have tried contacting the Customer Services Departments at all the major mobile phone manufacturers about this issue and got nowhere, (I was hoping to speak to a scientist or engineer in R & D on the bluetooth side). In contrast, when one of my email enquiries was picked up by someone at Motorola in the USA the response was very different.
[ This Message was edited by: mr beeb on 2003-06-02 21:25 ] |
orang3 Joined: Mar 28, 2002 Posts: > 500 From: Never_never_Land PM, WWW
you can enable the ans function vai voice command
Sex is like hacking. You get in, you get out, and you hope you didn't leave something behind that can be traced back to you |
JC#79 Blitz Joined: Apr 15, 2002 Posts: 92 From: London PM |
Hey guys you can answer your phone with the voice command on the hbh-30 when the phone rings the headset beeps you can then use the word answer or what ever word you specified to answer the call, not that hard 5 mins of playing around with it and what do you know bluetooth does have a use after all!!!!!!
pete Joined: Jul 29, 2002 Posts: 4 From: UK PM |
I've tried for a lot longer than 5 minutes, so what's the secret?? I'm using a T39 with HBH-30. |
with HBH 15 ... you can also do it ..
Yes, but how????? |
Good news! I own a HBH-30 now (latest SonyEricsson Bluetooth headset). I also have the latest firmware in my T68i = R2E006. Now I was finally able to automatically ANSWER a call with the HBH-30 without touching any button. How?
Goto: Settings - Voice Control - Voice Answer.
The first time you use this function, switch to ON. If you have the latest R2E006 version of the T68i, you will get 3 options:
- Car handsfree
- Port h-free
- Bluetooth.
Mark the 3rd option Bluetooth with the * key. Press YES and now you are required to record 2 voice-tags: ANSWER and REJECT (of course in your own language). Now you can answer and reject incoming calls with your bluetooth headset without any keys!
Good luck and post your findings!!
MMS
[ This Message was edited by: mms on 2002-07-31 13:21 ]
[ This Message was edited by: mms on 2002-08-06 06:45 ]
[ This Message was edited by: mms on 2002-08-06 06:47 ] |
Alhuang1 Joined: Jan 06, 2002 Posts: 30 PM |
I just used the suggested setting with my HBH 15 and it works! thanks a lot, mms I also, set one for my wife's t68 where she uses a motorala bluetooth headset and it also works. I've had both our phones upgraded to R2E006 software. Hope this helps others. |
Thanks for that, but on the T39, I can find no option for Bluetooth under the voice answer option, only port handsfree and car handsfree.
I think I'm on the latest firmware, but does anyone know if there is a patch for this like there is for t68??? |
