Forum > Sony Ericsson / Sony > Technical > Need bluetooth software - please help
Author Need bluetooth software - please help
doron_pascal
Posted: 2005-12-11 10:14
I need a bluetooth software to support HID, SPP profiles. HID For making my SE w800 remote control and SPP for file transfer from my cellphone to the pc.
I need the software to auto accept file transfer from my cellphone and auto save them in a preconfigured folder.
The perfect software to do so is "IVT" - BUT i need something more:
I need the software to allways try to detect if the device is near and automaticlly connect those 2 services with it.
I couldn't find that option in IVT.
Please if someone knows about that kind of program please tell me where can i get it.
Very big thanks!
BlinddogMS
Posted: 2006-02-08 13:15
Hi there !!!
Iīm looking for a remote control program for my w800, and I read your message but I couldnīt find any software..... did you find one? That IVT that you posted is one program? Where can I find it??
I appreciate your help... īcause Iīm totally "lost" here..... kkkkkkkkkk
Thanks and hugs from Brazil!
jcwhite_uk
Sony Xperia T
Posted: 2006-02-08 13:44
If you are using windows xp SP2 the remote control is already built into your system.
mattyplant
Posted: 2006-02-08 14:32
Yer was gonna say!
Upon completing the search with your pc, attach the phone to your computer, give it a password ie 12345 and it'll then ask for the same on your phone, so 12345.
Upon this your pc will start installing a keyboard and mouse, just next, next next with them.
And i believe the phone actually installs 7 things to your pc!!
Jools
C510 Black
Posted: 2006-02-08 15:18
Try Salling Clicker - very configurable
www.salling.com
Feisar.com
Hints, tips, software, themes & more for Apple Mac, iSync & Sony Ericsson users
