Forum > Sony Ericsson / Sony > Accessories > k750i housing fitting instructions please urgent!
Author k750i housing fitting instructions please urgent!
luketuttle
Posted: 2005-09-19 17:04
please can someone help me, i need some fitting instructions for the housing of the s/e k750i if you have them please can you post them or pm me with them thanx
masseur
Posted: 2005-09-19 17:26
[K750] Ripped apart......
[K750] Housing Swap 'How-To' II
luketuttle
Posted: 2005-09-19 17:32
thanx this realli realli helps
joven
W900 white
Posted: 2005-09-28 18:20
the site is gone!
any other similar tutorials?
dgilmartin
W900 black
Posted: 2005-10-07 11:04
@masseur
Those SENSE links above are no longer working. Is there anywhere that you know of where I can get K750i dismantling instructions, it seems a lot harder than swapping a K700i case anyway...
Cheers
Dan
All the Way! Looking for a w705 PM me! Arizona
masseur
Posted: 2005-10-07 11:39
well, se-nse chagned their forum software last weekend but the content is all there
so just for you I went and re-searched for these threads...
[K750] Housing Swap 'How-To' II Options
dgilmartin
W900 black
Posted: 2005-10-07 12:14
Thanks very Much Mate
The Bear
Posted: 2005-10-07 15:58
Can I just confirm that if I wanted to put the silver front and back from a K750i onto my W800i, then I would need to have the keypad as well? The pad surrounds look slightly different to me.
scotsboyuk
T68i
Posted: 2005-11-12 03:28
@The Bear
I'm not sure, if it doesn't say in either of those guides then I would suggest either erring on the side of caution and have a new keypad or message either of the authors of those guides and ask them.
cameraman
Posted: 2006-12-04 16:19
I have a W800i that needs cleaning inside. i dropped it once and dust got in. i took it to a phoner booth in the town to ask if H'ed open it for me but he wouldnt do it, said there was no point!
Well, i looked a that article and i reckn I could do it!
Now I know you need a torx screwdriver, but what size, or is there only one size?
Sammy_boy
C510 Black
Posted: 2006-12-04 16:23
It's a Torx T6 sized screwdriver you want, should be a fairly simple job to open it, especially with the posted guides. I'd suggest getting one of those plastic phone opening tools too, saves damaging the phone facia/chassis trying to prise it off with a screwdriver, much easier too, and easier on the fingernails!
cameraman
Posted: 2006-12-04 17:10
Thanks sammy boy.
You know what the guy recommeneded to get rid of the dust? One of those air canisters like they sell in Jesops. He said to blow down the earpiece with it and the dust will go.
Yea right,more likely I'll bugger me earpiece, and wheres the dust gonna go!
I'd have paid him to do it as well!
